Thread: 2017 A4 Allroad 3.0 TDi Tiptronic - Washer/wiper switch problem
  1. 2017 A4 Allroad 3.0 TDi Tiptronic - Washer/wiper switch problem
    Jun 2013
    Norwich, UK
    I've had this car for 4 years and this problem has appeared every now and then but currently very persistent.
    Sometimes the slightest touch on the washer/wiper stalk without even switching anything is enough to send the washer crazy and sometimes very hard to switch off again. Have even seen it caused by a bumpy road or sharp corner. There are no relevant faults showing on VCDS. The way it is behaving suggests to me that it is an intermittent connection or switch contact problem in that area. Has anyone seen anything similar or can suggest anything.
    My inclination is to try changing the Steering Column combi switch. However I'm having trouble deciding on what part number to look for as there seem to be about 50 possibilities for this VIN and PR combination. Best guesses so far are 4N0907129 AB or HD or MQ but really not sure. Hoping Crasher might be able to help with this (again!). VIN is WAUZZZF48HA011388.
    And a connected question: I believe that this switch assembly contains a control module - but does a replacement require coding?
    Thanks in advance
  2. Re: 2017 A4 Allroad 3.0 TDi Tiptronic - Washer/wiper switch problem
    131 Post(s)
    1978 Post(s)
    I didn't check for any repeat numbers but there are 195 different listings! WHY? Anyway, yours was 4M0 907 129 HD and is now 4N0 907 129 PG so obviously an issue, £368.40 retail inc.
  3. Re: 2017 A4 Allroad 3.0 TDi Tiptronic - Washer/wiper switch problem
    Jun 2013
    Norwich, UK
    Thanks Crasher.
    Yes - Why indeed. You can see why I was confused.
    You don't happen to know whether this part would need coding if swapped out do you?
  4. Re: 2017 A4 Allroad 3.0 TDi Tiptronic - Washer/wiper switch problem
    131 Post(s)
    1978 Post(s)
    Swapped out! You are an Englishman, not Merican I haven't done one of these yet but from looking at Elsa I suspect it would require ODIS.
  1. Rear wiper washer problem
    By beefio in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 13-02-2017, 02:16 PM
  2. A4 B6 Rear Wiper/Washer problem
    By Sullydog in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-01-2016, 07:36 PM
  3. Question Tiptronic problem or just switch issue?
    By trevorj13 in forum Golf MK4 - 1999 - 2004
    Last Post: 28-12-2011, 05:07 PM
  4. Please Help T4 wiper/ washer switch+ steering wheel
    By olliecat in forum The Classic VW's
    Last Post: 18-07-2010, 03:45 PM
  5. Wiper and washer problem
    By iBiff in forum Bora - 1998 - 2005
    Last Post: 08-01-2010, 11:01 PM
