Thread: Esp/abs error symptoms
  1. Esp/abs error symptoms
    May 2025
    Yorkshire
    I've just started getting an esp/abs error on my 2010 Golf plus 2 litre diesel automatic. Sometimes the error comes up when I turn the ignition, sometimes it might come up after a short while of driving. The asb and traction control lights come on. Sometimes it lets out a high pitched constant beep to replace the parking sensor beeping, sometimes it doesn't and the parking sensors work fine. Every so often the traction control light will go out early in a journey and then the car will sometimes drop down a gear and rev high, revving higher in gear changes than it does in sports mode. This can be stopped by slowing down, with the traction control light coming back on with a reminder about the esp/abs issue and the automatic gear shifts return to normal. I haven't tried testing the abs yet.
    Do these symptoms suggest anything in particular? I plan to clean the abs sensors in the hubs but will get it to the garage if these symptoms suggest something more complicated.
    Thanks for reading,
    Dave
  2. Re: Esp/abs error symptoms
    134 Post(s)
    2022 Post(s)
    Get it code read first, removing the sensors breaks them.
  1. Please Help ABS error + radio error + air quality sensor error + CAN gateway error
    By chilly1g in forum Scirocco - 2008-
    Last Post: 29-07-2024, 10:17 AM
  2. Question Symptoms
    By AndyQjay in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 30-04-2015, 09:18 PM
  3. Replies: 0
    Last Post: 09-09-2012, 10:42 PM
  4. S3 Haldex error 65535 internal control module memory error?
    By merlin2002 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 16-06-2009, 09:08 AM
  5. Please help , look at these symptoms.
    By nutter1980 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-12-2007, 02:00 AM
