Thread: 2013 caddy 1.6tdi
  1. 2013 caddy 1.6tdi
    Sep 2018
    Yorkshire
    Morning guys
    I’m hoping for some advice,
    The eldest has bought a caddy. It had leaking injectors when we got it so we’ve replaced seals and returns.
    however it has a few fault codes showing and seems to jitter sometimes around 2500 rpm. Sometimes it revs through lovely.
    The fault codes at the minute are in the photo attached,
    a few things I’ve noticed is,
    it’s had new 02 sensors however I feel these arnt the cause of that code. (Willing to buy new if it is likely though)
    oil light flashes randomly normally just as your setting off or slowing down
    steam from the rear of the engine
    is there anything I should be looking for?
    im going to start stripping down later but sometimes there are common issues where I should look first so I thought I’d ask here.
    any advice welcome
    I will be flushing the oil and changing oil and filter also
    regards
    dan
  2. Re: 2013 caddy 1.6tdi
    Sep 2018
    Yorkshire
    I’ll try to keep this updated in case it helps anyone else in the future.
    stripped down a few bits today, the steam from the rear is actually oil vapour as the rocker cover has split.
    ive stripped the fuel rail can’t see any brass swarf in there.
  3. Re: 2013 caddy 1.6tdi
    Sep 2018
    Yorkshire
    Turns out someone has fitted fuel lines wrong way.
    it now runs lovely.
    however the brand new return lines are leaking.
    so need to work out why this is, maybe just cheap parts
  1. Caddy 1.6TDi CAYD engine new cambelt kit fitted but whining noise
    By 3wheeler7 in forum The Commercial Range
    Last Post: 05-08-2022, 10:44 AM
  2. Replies: 25
    Last Post: 16-11-2020, 04:22 PM
  3. 2011 Caddy 1.6TDI wont start (vcds says Brake light Switch)
    By AudisportUK in forum The Commercial Range
    Last Post: 29-10-2019, 08:01 PM
  4. Important caddy 1.6tdi secondary air pump location
    By luigino007 in forum The Commercial Range
    Last Post: 06-12-2015, 07:56 PM
  5. Caddy 1.6tdi injectors
    By sparky james in forum The Commercial Range
    Last Post: 19-10-2014, 06:20 PM
