Thread: A3 s-line 2013 3 door fuse box locations?
  1. A3 s-line 2013 3 door fuse box locations?
    May 2025
    Sheffield, UK
    Sorry if its been posted before but cant find it by searching, but can anyone tell me the fusebox locations, Car is a right hand drive model, i have found the one next to the battery under the bonnet but trying to find any others is madness!
    wow my first post, probably one of many!
  2. Re: A3 s-line 2013 3 door fuse box locations?
    131 Post(s)
    1976 Post(s)
    Right hand side of the dash behind the cover, this box is called SC, the one in the engine bay along the top is SB and those along the front of the box are SA. Some cars will have a fourth box on the left side of the dash and this is SD.
  3. Re: A3 s-line 2013 3 door fuse box locations?
    May 2025
    Sheffield, UK
    Nothing behind either end driver or passenger, if your referring to the sides of the dash, but looking at the pics below i wouldnt say theres a fusebox on that side at all?
  4. Re: A3 s-line 2013 3 door fuse box locations?
    131 Post(s)
    1976 Post(s)
    I thought it was an 8P A3, not an early 8V, I should have looked at the title, the fuse box and central electrics are behind the glovebox on the far left as per Golf 7 as the 8V is MQB platform. This is an Octavia but it is the same
  5. Re: A3 s-line 2013 3 door fuse box locations?
    May 2025
    Sheffield, UK
    Wow, looks like im taking half the dash out lol !
  6. Re: A3 s-line 2013 3 door fuse box locations?
    131 Post(s)
    1976 Post(s)
    What are you planning on doing?
  7. Re: A3 s-line 2013 3 door fuse box locations?
    May 2025
    Sheffield, UK
    trying to pin point an issue with the window and indicator on the passenger side, initial reaction - check fuses, everything checks out ok, but only moments later i jump in the drivers seat, turn engine over, it didnt start so i took key back to off then switched engine on again, then all of a sudden lost everything on the dash including the infotainment, car wont start or do anything
    codes thrown out are
    Engine control module
    u15500 lost communication with instrument panel cluster (ipc) control module
    p157000 engine control module (ecm) disabled
    u042800 invalid data received from steering angle sensor module
    central electrics
    b140e13 voltage supply terminal 30, right, open circuit
    b142313 voltage supple terminal 30 power, open circuit
    b1330f5 anti theft alarm system sensor, alert emergency activation stage 1
    u112100 databus missing message
    gateway
    u020000 lost communication with door control module b
    information control unit
    b200087 control module software incompatible
    u110100 component protection active
    u10e400 multimedia system control head no communication
    so all i can say is, it certainly wasnt planned!!!
  8. Re: A3 s-line 2013 3 door fuse box locations?
    May 2025
    Sheffield, UK
    do you know where the main BCM is located, im assuming thats gone **** up and im assuming the one in the door is probably at fault as well.... what happened to good old fashioned fuses eh?
  9. Re: A3 s-line 2013 3 door fuse box locations?
    131 Post(s)
    1976 Post(s)
    The BCM is right there end on in the picture to the left of the fuse board at a slight angle sandwiched between the A pillar and the fuse board, is an absolute ******* to get out but thankfully not prone to failure; if it does need replacing, replacement is not plug and play and even VCDS can’t set up a new one. Looking for fuses to solve your problem is unlikely to help as few items are fused even though there are lots of fuses! You problem is quite clearly indicated by the terminal (Line) 30 codes and this circuit is commanded by the 645 Line 15 relay on the fuse board, VW part number 4H0 951 253 A which retails at £32.94 from any VAG main dealers parts department or a TPS if they will serve you.
  1. Alhambra 7N model Fuse locations
    By HM-BorderReiver in forum Alhambra
    Last Post: 15-03-2017, 09:30 AM
  2. A4 B8 Fuse Locations and distribution
    By nancol in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 09-01-2013, 11:43 PM
  3. Please Help Fuse Locations for:
    By ToMBoY_C in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-12-2010, 05:56 PM
  4. Passat 2010 fuse locations
    By beneast in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 17-08-2010, 02:25 PM
  5. fuse box locations
    By biggie21 in forum Golf MK3 - 1993 - 1999
    Last Post: 10-02-2008, 09:13 AM
