Thread: ABS/TPMS warning lights came on
Results 1 to 10 of 20
  1. ABS/TPMS warning lights came on
    Oct 2023
    near Letham Fife
    With warning codes 1325 an 1324.
    1324 i'm already aware of but 1325 control unit of TPMS malfunction.
    What system is fitted to my Q3 vin WAUZZZ8U5ER146533.
    Kenny
  2. Re: ABS/TPMS warning lights came on
    2021 Post(s)
    There are two variations of 01325
    01325 - Control Module for Tire Pressure Monitoring (J502) : No or Incorrect Basic Setting / Adaptation
    01325 - Control Module for Tire Pressure Monitoring (J502) : No Signal/Communication
    Yours has Pr-7K1 indirect wheel speed based TPMS, the direct system is a PITA.
  3. Re: ABS/TPMS warning lights came on
    Oct 2023
    near Letham Fife
    Thanks for the reply,
    I checked the wiring to all the ABS sensor 3 were fine, the other sensor has a wire is partially exposed and the other has is cracked unknown if through to the copper (possible problem).
    I have checked and adjusted the tyre pressure.Will see if that makes a difference.
    Have a new plug for sensor and will use it to replace damaged wiring.
    Kenny
  4. Re: ABS/TPMS warning lights came on
    Oct 2023
    near Letham Fife
    With this system I thought there was no module fitted for the TPMS. It was the ABS module which monitored the Tyres via the speed sensors ie their circumference.
    Also could the ambient outside air temp sensor affect this system.
    Kenny
    PS changed plug to sensor due to damaged wiring still lights on.
  5. Re: ABS/TPMS warning lights came on
    2021 Post(s)
    Yes, it is based on wheel speed from the ABS ECU, I can’t imagine the temp sender having an influence but it could be digitally linked to take into account air density changes.
  6. Re: ABS/TPMS warning lights came on
    Oct 2023
    near Letham Fife
    Can it confirmed where TPMS is re my Audi ?
    Is fitted in the ABS module itself or elsewhere?
    I suspect a dodgy wire. So a relevant wiring diagram for my Audi would be helpful. I have a diagram for 2011 onwards but I feel something is missing.
    Kenny
  7. Re: ABS/TPMS warning lights came on
    2021 Post(s)
    It is a software routine in the ABS ECU, you need to study the wheel speeds in measuring blocks. Which fault codes are you getting now?
  8. Re: ABS/TPMS warning lights came on
    Oct 2023
    near Letham Fife
    Still getting the same fault codes
    1324 which is my awd module
    1325 TPMS no signal / comms
    I checked the fuses all fine, carried out continuity tests on front sensor wiring seemed fine.
    But I need a full dry day to get to the ABS plug to measure the voltages and resistances over all the speed sensor wires.
    Kenny
  9. Re: ABS/TPMS warning lights came on
    2021 Post(s)
    Thinking back, we had this with a TT2 and a Gen4 Haldex, it was the Haldex ECU at fault, water damage. Yours could be Haldex 4 or 5, can you post a full car VCDS scan?
  10. Re: ABS/TPMS warning lights came on
    Oct 2023
    near Letham Fife
    Thanks Crasher,
    Mine is gen 5, suspect water damage. It has not been working since I got the vehicle. Module number OAY 907 554J got this from the unit on the car dated 17/11/2014.
    In ABS module on VCDS it has measurments, what does it cover ? I'm thinking about the magnetic strip on the wheel hub, could this be the problem ?
    I'm going to drive the car with VCDS attached to measure the wheel speed sensors.
    Address 03: ABS Brakes (5N0 614 109 BA)
    09:20:55 Group 001: Current Wheel Speed
    17.0 km/h Speed Sensor Front Left (G47)
    17.0 km/h Speed Sensor Front Right (G45)
    17.0 km/h Speed Sensor Rear Left (G46)
    17.0 km/h Speed Sensor Rear Right (G44)
    09:23:25 Group 001: Current Wheel Speed
    78.0 km/h Speed Sensor Front Left (G47)
    78.0 km/h Speed Sensor Front Right (G45)
    77.0 km/h Speed Sensor Rear Left (G46)
    77.0 km/h Speed Sensor Rear Right (G44)
    Live data I took today via measurement block, from this the wiring from sensors are working. So what is causing the warning lights to come on ?
    Any thoughts please,
    Further to the above removed AWD module and water ingress found. Hence it is NO signal or comms.
    Kenny
  1. ESC stabilisation fault and TPMS warning
    By Davis XI in forum Audi A3 - 8V - 2012 - 2016
    Last Post: 12-08-2024, 03:04 PM
  2. Please Help Audi a3. 1.6 tdi, 2011, sportback - TPMS system warning, Start/Stop not available ? Injectors?
    By curiousBog in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-02-2024, 01:55 PM
  3. Three Warning Lights come on together, Stability, TPMS and Steering Angle
    By Pauls898 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 10-11-2020, 08:42 PM
  4. 1.6 TDI ESP and TPMS lights on
    By dgirllamius in forum Polo - Derby - Lupo - Fox
    Last Post: 30-05-2018, 08:02 PM
  5. Replies: 4
    Last Post: 08-05-2012, 01:21 PM
