Thread: ABS/TPMS warning lights came on
Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. Re: ABS/TPMS warning lights came on
    Oct 2023
    near Letham Fife
    Further to the above car taken for a drive with son who monitored the WSS in the measuring block and saw no anomalies.
    What is going on ?
    Attached latest autoscan
    Code:
    Monday,16,June,2025,12:37:23:14471
    VCDS Version: 25.3.1.2 (x64)  HEX-V2 CB: 0.4671.4
    Data version: 20250604 DS365.0
    Ross-Tech: Home
    VIN: WAUZZZ8U5ER146533   License Plate: KX64NDZ
    Mileage: 148750km-92428mi   Repair Order:
    Chassis Type: 8U-AU21 (8U0)
    Scan: 01 02 03 08 09 10 15 16 17 19 22 25 42 44 46 52 53 55 5F 62
              72
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    10-Park/Steer Assist -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    22-AWD -- Status: Cannot be reached 1100
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    Address 01: Engine (J623-CFGC)       Labels:. 03L-906-018-CFF.clb
       Part No SW: 03L 906 018 PH    HW: 03L 906 018 ES
       Component: R4 2.0l TDI   H28 9979
       Revision: 41H28---    Serial number:                CVN: F3FD3413
       Coding: 00250012043701080000
       Shop #: WSC 54992 002 1048576
       ASAM Dataset: EV_ECM20TDI01103L906018PH 003009
       ROD: EV_ECM20TDI01103L906018PH.rod
       VCID: 7F5B10CF377EF482F63-802A
       VINID: 9D196AAAA2251558811061430C440903E9
    1 Fault Found:
    5286 - Throttle Position Sensor (G69)
              P0121 00 [01100000] - Implausible Signal
              Intermittent - Not Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 148596 km
                        Date: 2025.06.14
                        Time: 22:34:58
                        Engine speed: 546.00 /min
                        Normed load value: 100.0 %
                        Vehicle speed: 0 km/h
                        Coolant temperature: 73 °C
                        Intake air temperature: 16 °C
                        Ambient air pressure: 1000 mbar
                        Voltage terminal 30: 13.700 V
                        Unlearning counter according OBD: 39
                        Air mass: actual value (mg/stroke): 473.0 mg/stroke
                        Throttle valve adapter: specified value: 0.00 %
                        Throttle valve adapter: actual value: 1.42 %
                        Throttle valve adapter: offset closed: -12.05 %
                        Throttle valve adapter: status-Bits 0-7: 0
                        Throttle valve adapter: status-Bits 0-7: 55
                        Throttle valve adapter: status-Bits 0-7: 2
                        Throttle valve adapter: status-Bits 0-7: 8
                        Throttle valve adapter: uncond voltage actual value: 992.0 mV
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans (J743)       Labels:. 0BH-927-711.clb
       Part No SW: 0BH 300 012 A    HW: 0BH 927 711 C
       Component: DSG DQ500-7A  H08 2233
       Revision: 00H08V01    CVN: 4F80FCDC
       Coding: 0014
       Shop #: WSC 00000 000 00000
       ASAM Dataset: EV_TCMDQ500021 001001
       ROD: EV_TCMDQ500021.rod
       VCID: 211FF6B7E14A6272A07-8074
    No fault code found.
    Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
       Part No SW: 5N0 614 109 BA    HW: 5N0 614 109 BA
       Component: J104   C6 450M VDB7 0160
       Revision: --H07---    Serial number: 00000008571821
       Coding: 0056717
       Shop #: WSC 00049 770 00151
       VCID: 6B83D49F5F8678224AB-803E
    2 Faults Found:
    01324 - Control Module for All Wheel Drive (J492)
                004 - No Signal/Communication
                 Freeze Frame:
                        Fault Status: 01100100
                        Fault Priority: 3
                        Fault Frequency: 10
                        Reset counter: 183
                        Mileage: 148584 km
                        Time Indication: 0
                        Date: 2025.06.14
                        Time: 14:03:11
                 Freeze Frame:
                        Speed: 0.0 km/h
                        Hex Value: 0x0000
                        Bin. Bits: 00000000 00000000
                        Voltage: 12.00 V
                        Bin. Bits: 00011111
                        Count: 256
                        Hex Value: 0x0000
    01325 - Control Module for Tire Pressure Monitoring (J502)
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 10
                        Reset counter: 183
                        Mileage: 148584 km
                        Time Indication: 0
                        Date: 2025.06.14
                        Time: 14:03:21
                 Freeze Frame:
                        Speed: 0.0 km/h
                        Hex Value: 0x0000
                        Voltage: 12.00 V
                        Bin. Bits: 00011111
                        Count: 191
                        Hex Value: 0x0000
    Address 08: Auto HVAC        Labels: 8P0-820-043.lbl
       Part No SW: 8U0 820 043 D    HW: 8U0 820 043 D
       Component: E87  Klimavoll      0100
       Revision: 00H04000    Serial number: 8U0820043D
       VCID: 323D09FBB82CE9EA49D-8066
    Address 09: Cent. Elect. (J519)       Labels:. 8X0-907-063.clb
       Part No SW: 8X0 907 063 AB    HW: 8X0 907 063 AB
       Component: BCM PQ35  M   113 0817
       Revision: AB113817
       Coding: 0E000A2CA805F1C0201841C00104094C43FF84AA206F912BE400878400C1
       Shop #: WSC 00049 770 00099
       VCID: 7CA1E7C326E8EF9AD31-8028
       Subsystem 1 - Part No SW: 8U2 955 119     HW: 8U2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS316 141026  H37 0090
       Serial number:         141105212039
       Coding: 0047F7
       Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
       Component: G397_RLFS  H06 0002
       Serial number: 23427357
       Coding: 02006E
       Subsystem 3 - Part No: 8X0 951 177
       Component: DWA-Sensor H0  H01 0020
       Subsystem 4 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HO  H05 1501
    Address 10: Park/Steer Assist (J446)       Labels:| 8X0-919-475.clb
       Part No SW: 8X0 919 475 AD    HW: 4H0 919 475 AG
       Component: PARKHILFE 8K  H01 0070
       Revision: 11001001    Serial number: 61031431600371
       Coding: 08C305
       Shop #: WSC 00049 770 00117
       ASAM Dataset: EV_EPHVA18AU21X0000 003008
       ROD: EV_EPHVA18AU21X0000_003.rod
       VCID: 08498B1362B0B33AC79-805C
    1 Fault Found:
    1112082 - Front Left Center Parking Aid Sensor
              B10F8 12 [00001000] - Short to Plus
              Intermittent - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 161
                        Mileage: 147659 km
                        Date: 2025.06.01
                        Time: 15:22:43
    Address 15: Airbags (J234)       Labels:| 8X0-959-655.clb
       Part No SW: 8U0 959 655 B    HW: 8U0 959 655 B
       Component: AirbagVW-AU10 H09 0520
       Serial number: 003LRR09RPHR   Dataset Number: 8U0909602A  0009
       Coding: 30393132313030303030554A305238553053
       ASAM Dataset: EV_AirbaAU10SMEAU316 001005
       ROD: EV_AirbaAU10SMEAU316_001.rod
       VCID: 46D5452B2824654AF55-8012
       Crash sensor for side airbag: driver side:
       Subsystem 1 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
       Component: S.Sens.Fahr.V  H02 ----
       Serial number: 3496KSME12033C33ZZZN
       Crash sensor for side airbag: passenger side:
       Subsystem 2 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
       Component: S.Sens.Beif.V  H02 ----
       Serial number: 3506KSME13213C33ZZZG
       Rear Side Airbag Crash Sensor (on driver's side):
       Subsystem 3 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
       Component: S.Sens.Fahr.H  H02 ----
       Serial number: 3516KSME502A2B33ZZZP
       Passenger side rear thorax airbag crash sensor:
       Subsystem 4 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
       Component: S.Sens.Beif.H  H02 ----
       Serial number: 3526KSME73041533ZZZG
       Crash sensor for front airbag: driver side:
       Subsystem 5 - Part No SW: 8U0 959 651     HW: 8U0 959 651
       Component: F.Sens.Fahr  H02 ----
       Serial number: 3555USME05292D31ZZZ.
    Address 16: Steering wheel (J527)       Labels:| 8X0-953-569.clb
       Part No SW: 8X0 953 521 D    HW: 5K0 953 569 AE
       Component: LENKS.MODUL   016 0162
       Revision: FF010018    Serial number: 20141115201145
       Coding: 1894204000
       ASAM Dataset: EV_SMLSNGVOLWSXS A01004
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 3D272AC77DF22692A4F-8068
       Multifunction steering wheel control module:
       Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
       Component: E221 - MFL  H08 0010
       Serial number: 08 11 2014  E0024653
    Address 17: Instruments (J285)       Labels:| 8X0-920-KOM-V1.clb-SRI1
       Part No SW: 8U0 920 980 E    HW: 8U0 920 980 E
       Component: KOMBI_MEDIUM  H02 0340
       Serial number: 00000000000000
       Coding: 42CF01
       ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
       ROD: EV_Kombi_UDS_VDD_AU10.rod
       VCID: 3E252DCB70F43D8ABD5-806A
    Address 19: CAN Gateway (J533)       Labels:. 8X0-907-468.clb
       Part No SW: 8U0 907 468 AC    HW: 8U0 907 468 G
       Component: GAT 4CAN 1L M H13 0074
       Revision: 1P140041    Serial number: 4141P14B080442
       Coding: FBCF1A5A000100610353
       VCID: 03539C3F5B16906292B-8056
       Subsystem 1 - Part No SW: 1K0 915 181 H    HW: 1K0 915 181 A
       Component: J367-BDM  H07 0180
       Serial number: 41317M13361491092650
       Subsystem 2 - Part No SW: 8K0 959 663     HW: 8K0 959 663
       Component: J532_DCDCStab  H17 0042
       Serial number: 14321002703021200181
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 181
                        Mileage: 148584 km
                        Time Indication: 0
                        Date: 2025.06.14
                        Time: 14:04:03
                 Freeze Frame:
                        Bin. Bits:    10111
                        Voltage: 12.20 V
                        Count: 6
                        Bin. Bits:    10000
                        Time: 25.40 s
    Address 22: AWD
    Cannot be reached
    Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
       Component: IMMO          H02 0340
       Serial number:
       Coding: 000002
       ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04113
       ROD: EV_Immo_UDS_VDD_AU10.rod
    Address 42: Door Elect, Driver (J386)       Labels:. 8X0-959-793.clb
       Part No SW: 8X0 959 793 H    HW: 8X0 959 793 H
       Component: TSG FA        H11 0415
       Revision: --------    Serial number: --------------
       Coding: 011806200001000000
       VCID: 52FD697BD4ECC9EA69D-8006
    Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
       Part No: 5N0 909 144 R
       Component: EPS_ZFLS Kl. 296    3501
       Revision: 00H22000
       VCID: 40D9533306804B7ACF9-8014
    Address 52: Door Elect, Pass. (J387)       Labels:. 8X0-959-792.clb
       Part No SW: 8X0 959 792 H    HW: 8X0 959 792 H
       Component: TSG BF        H11 0415
       VCID: 51FF6677D1EAB2F2507-8004
    Address 53: Parking Brake        Labels: 3AA-907-801.clb
       Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
       Component: J540 EPB4  VW-63206 0012
       Revision:   H19       Serial number: 00000000377958
       Coding: 0025166
       VCID: 38293BD35E5003BA779-806C
    Address 55: Headlight Range (J431)       Labels:| 8X0-907-357.clb
       Part No SW: 8X0 907 357 C    HW: 8X0 907 357 B
       Component: ****LWR12**** H02 0020
       Serial number: 141116-0001-012
       Coding: 1157A41010002500
       ASAM Dataset: EV_HeadlRegulBasic 005001
       ROD: EV_HeadlRegulBasic_AU21.rod
       VCID: 42DD593B040C596AD9D-8016
    Address 5F: Information Electr. (J794)       Labels: None
       Part No SW: 8U0 035 192 E    HW: 8U0 035 192 C
       Component: RMC Nav Plus  H55 0801
       Coding: 01010600024153070823020103010000000000
       VCID: 363535EB5844F5CA655-8062
       Subsystem 1 - Part No: 8X0 919 884 H
       Component: P28-50-14.06  0001
       Subsystem 2 - Part No SW: 8U0 919 603 A    HW: 8U0 919 603 A
       Component: DUBasic AU316  H42 0018
       Serial number: AUZ8ZDEM502AD8X
    Address 62: Door, Rear Left (J388)       Labels:. 8X0-959-795.clb
       Part No SW: 8X0 959 795 C    HW: 8X0 959 795 C
       Component: TSG HL        H08 0415
       Coding: 010006200001000000
       VCID: 4FFB600FC7DEA402463-801A
    Address 72: Door, Rear Right (J389)       Labels:. 8X0-959-795.clb
       Component: TSG HR        H08 0415
    End----------(Elapsed Time: 01:39, VBatt start/end: 11.8V/12.1V)-----------
    ------------------------------5 Faults Found-------------------------------
  2. Re: ABS/TPMS warning lights came on
    134 Post(s)
    2021 Post(s)
    Standard Gen 4 Haldex ECU water damage failure, yours could be Gen 4 or 5 so you need to look at the data sticker to see if the final drive is MBD, NVK or PYN or if it is Gen 5 then PGA or QLY but I have not seen Gen 5 do this. An earlier code read when the Haldex ECU was still talking would also help.
  3. Re: ABS/TPMS warning lights came on
    Oct 2023
    near Letham Fife
    It's a gen 5 and there clear signs of water damage on circuit board.
  4. Re: ABS/TPMS warning lights came on
    134 Post(s)
    2021 Post(s)
    New ECU then, 0AY 907 554 J, being Gen 5 they are half the price of Gen 4 but still £747.60 retail inc. Remove the pump, clean out the usually crud, flush with brake cleaner and compressed air and rebuild.
  5. Re: ABS/TPMS warning lights came on
    Oct 2023
    near Letham Fife
    Thanks Crasher,
    Will get onto that, but I realised a mistake made by myself.
    My fault lights are ESC and TPMS : ESC is a fault and TPMS is a malfunction. Could this all relate to the AWD module fault ?
    Here attached
    Component: J104 C6 450M VDB5 0160
    Coding: 0056717
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 86
    Reset counter: 181
    Mileage: 147648 km
    Time Indication: 0
    Date: 2025.06.01
    Time: 13:34:35
    Freeze Frame:
    Speed: 0.0 km/h
    Hex Value: 0x0000
    Voltage: 12.00 V
    Bin. Bits: 00011111
    Count: 256
    Hex Value: 0x0000
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 86
    Reset counter: 181
    Mileage: 147648 km
    Time Indication: 0
    Date: 2025.06.01
    Time: 13:34:45
    Freeze Frame:
    Speed: 0.0 km/h
    Hex Value: 0x0000
    Voltage: 12.00 V
    Bin. Bits: 00011111
    Count: 191
    Hex Value: 0x0000
  6. Re: ABS/TPMS warning lights came on
    134 Post(s)
    2021 Post(s)
    That is what I have seen with Gen 4 water damage but not yet seen it with Gen 5.
  7. Re: ABS/TPMS warning lights came on
    #17
    Oct 2023
    near Letham Fife
    I made a mistake, it is the ESP warning light which is on, NOT the ABS light.
    Will post update when I get a result.
    Kenny
  8. Re: ABS/TPMS warning lights came on
    #18
    134 Post(s)
    2021 Post(s)
    We all do that, it’s called being human.
  9. Re: ABS/TPMS warning lights came on
    #19
    Oct 2023
    near Letham Fife
    FYI, I did another driving test using the adv measuring port in graph form and it didn't show any drop offs or spikes in the graph.
    So basically VCDS is measuring and displaying speed values, if there was/is a problem with the sensors it is very intermittent and difficult to detect.
    As suggested already AWD module is the probable cause.
    Will get back to forum once all is in place with a result.
  10. Re: ABS/TPMS warning lights came on
    #20
    Oct 2023
    near Letham Fife
    Will the ESP switch if broken affect the system and activate the warning light in the dash ?
    To test the switch using multi meter check for continuity in resistance mode ?
    Kenny
  1. ESC stabilisation fault and TPMS warning
    By Davis XI in forum Audi A3 - 8V - 2012 - 2016
    Last Post: 12-08-2024, 03:04 PM
  2. Please Help Audi a3. 1.6 tdi, 2011, sportback - TPMS system warning, Start/Stop not available ? Injectors?
    By curiousBog in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-02-2024, 01:55 PM
  3. Three Warning Lights come on together, Stability, TPMS and Steering Angle
    By Pauls898 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 10-11-2020, 08:42 PM
  4. 1.6 TDI ESP and TPMS lights on
    By dgirllamius in forum Polo - Derby - Lupo - Fox
    Last Post: 30-05-2018, 08:02 PM
  5. Replies: 4
    Last Post: 08-05-2012, 01:21 PM
