Thread: Q7 Coolant leak in V Part Numbers
  1. Q7 Coolant leak in V Part Numbers
    Sep 2011
    Sheffield
    I have a coolant leak in the V. Was wanting to order every part i'll need before stipping it down.
    2016 tdi
    Does anybody have the complete part numbers for this please?
  2. Re: Q7 Coolant leak in V Part Numbers
    2015 Post(s)
    That is a LOT of numbers, it is a long job. What is the VIN?
  3. Re: Q7 Coolant leak in V Part Numbers
    Sep 2011
    Sheffield
    Hi, the vin number is WAUZZZ4M9GD051091
    Struggling to work out the parts I need - parts service seemed no help
  4. Re: Q7 Coolant leak in V Part Numbers
    2015 Post(s)
    Audi parts department? Help?
    I have half an hour to Vodka o’clock (can’t be trusted after), so here goes (and this is parts required from memory)
    ALL prices are Audi retail PLUS VAT.
    Oil cooler gasket 059 117 070 K£18.90
    Bolts x 6 N 101,243 06 £1.25 each
    Valve 059 121 737 AR £138 (they’ve gone up!)
    Bolt x 3 N 101 961 03 £1.05
    4 ish litres of G12 Evo €7 litre
    Bolt x 14 WHT 006 896 £1.85 each
    Seal x 12 059 12 717 S £6.05
    Seal 059 129 069 E £25.20
    Seal 059 129 215 N £14.45 (revised)
    O ring 059 129 796 J £16.05 (revised)
    O ring 059 145 865 C £12.70
    Bolt x 4 N 105 680 01 £0.95
    EGR pipe gasket 059 131n358 G £6.70
    IF you want to revise the intake system whilst it is off or find it is clogged
    Throttle valve adapter 059 129 593 AR £437 available aftermarket
    Air pipe 059 145 762 DN £127.50
    Throttle valve 059 145 950 BH £387 available aftermarket
    IF you want to fit the revised manifold 059 129 711 EA £691
    Revised intermediate flange x 2, 059 129 765 R £82.30 comes with seals
    Bolts x 16 N 911 482 01 £0.88 each
    You could also go mad and fit the revised EGR system 059 131 511 D £661 available aftermarket
    Can’t think of anything else and my Vodka alarm just went off
  5. Re: Q7 Coolant leak in V Part Numbers
    Sep 2011
    Sheffield
    Thank you so much! Hope you enjoyed the vodka!
  1. Question Help with part - leak in breather hose - part number or fix? (Photo attached)
    By Mkvstillalive in forum Golf MK5 - 2004 - 2009
    Last Post: 24-09-2022, 03:56 PM
  2. Question Coolant leak - what is part this called and is it realistic for me to attempt to fix?
    By ianlovatt in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-09-2020, 01:36 PM
  3. Help with part numbers/ID
    By Hanny in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-10-2009, 01:05 PM
  4. Part Numbers
    By Fozmondo in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-06-2009, 01:59 PM
