Thread: Oil consumption level from MMI
  1. Oil consumption level from MMI
    Apr 2025
    IT
    I recently took an A7 3.0 218cv of 2016 with 180k km and I'm keeping an eye on the oil level from the central computer or mmi, I realized that at a distance of about a week and 1700 km traveled it has dropped about half a centimeter compared to when I bought it, could it be some problem regarding the sensors? Or maybe I checked the first time while it was still with a hot engine and the second time while moving on the road?
    Could someone with a good heart who has the same "problem" as me explain?
    Or maybe it's just me wagging my head...
    Thank you so much!
    Inviato dal mio SM-S928B utilizzando Tapatalk
  2. Re: Oil consumption level from MMI
    135 Post(s)
    2026 Post(s)
    It could have been on the edge of dropping, to be accurate you need a dip stick; to be REALLY accurate on oil consumption you have to drain the oil, weigh it, put it back, do 620 miles and drop/weight the oil again, using a per gram value (can't remember it) you can then work out the consumption per 1000 kilometers.
  3. Re: Oil consumption level from MMI
    Apr 2025
    IT
    I'll try later as you said, hoping that there's someone who's found my own doubt, thank you
  1. Question Oil level light on but oil level is fine (after recent oil change)
    By mvdg in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-11-2019, 09:10 PM
  2. Low Oil Level Warning Light on but level OK - Anything else to check
    By new2vwa in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-10-2013, 07:03 PM
  3. Oil level warning light on BUT oil level is correct!
    By VAGMAN2 in forum Golf MK5 - 2004 - 2009
    Last Post: 02-08-2011, 07:44 PM
  4. Oil consumption
    By olliecampbell in forum Golf MK4 - 1999 - 2004
    Last Post: 01-07-2009, 10:37 AM
  5. Question Oil consumption
    By MalcQV in forum Chat - Anything with wheels
    Last Post: 27-01-2009, 09:45 AM
