Thread: no steering after instrument cluster swap
  1. no steering after instrument cluster swap
    Nov 2022
    Bulgaria
    The car is 2005 Altea the original cluster is defective (00003 - Control Module: Defective) after swap with cluster from parts car the error for defective instrument cluster is gone but I get 2 errors in steering assist
    02546 - Steering Limit Stop: No or Incorrect Basic Setting / Adaptation
    00778 - Steering Angle Sensor (G85): No or Incorrect Basic Setting / Adaptation
    I know how to fix this but... The security code(40168) is invalid
    done the procedure with rotating the steering wheel all the way right and left and driving the car no change.
    I noticed that G85 is showing 0.00 when turning the wheel.
    Is there a chance that G85 is fried ?
  2. Re: no steering after instrument cluster swap
    2018 Post(s)
    Did you have to remove the wheel to change the panel. How did you deal with the immobiliser matching?
  1. Question Instrument Cluster Swap
    By hufodorp in forum Golf MK6 - 2009 - 2013
    Last Post: 18-01-2018, 01:16 PM
  2. Instrument cluster
    By pricey01 in forum Golf MK5 - 2004 - 2009
    Last Post: 23-01-2011, 08:06 AM
  3. Please Help Instrument cluster swap
    By astro303 in forum Golf MK3 - 1993 - 1999
    Last Post: 12-02-2009, 05:40 AM
  4. Swap out the instrument cluster B5 Passat AFN
    By charliecwmboy in forum VCDS - General Questions
    Last Post: 04-11-2008, 08:15 PM
  5. Instrument Swap 3B with 3BG
    By hotrod09 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-04-2008, 12:55 PM
