Hi.
Having problems with my reverse lights, oil level sensor, door electronics and ac electronics. The fuse nr. 4 in the dash is blowing every time i turn on the ignition. I have tested some opions that i have seen here in the forum but it still blows. Does anyone have some good advice?
I have replaced the black/purple wire that goes from the fuse boks in the dash to the oil level sensor with a new one and the the fuse stoped blowing. but the other problems are stil there. the biggest problem is the reverse lights not working.
Any one have a wiring diagram for this? or tips is a big yes
I have the following fault codes:
