Thread: TDI 2.0 CFH Intermittent non-starting issue
  1. TDI 2.0 CFH Intermittent non-starting issue
    Mar 2025
    Derbyshire
    Hi guys,
    Hope you're all good.
    Just wanted to say I've been a long time viewer but a new poster.
    I'm recently having an intermittent issue with my motor. It starts up fine 95% of the time with no issues, It has been my daily runaround to work and back with no issues.
    On two occasions I have taken it out for less than 20 minutes and then when going to start it, it just cranks over until the battery dies. There doesn't appear to be any pattern, it just does it when it wants to.
    Eventually, it will burst back into life and fire up as if nothing has happened.
    When it cranks there is no RPM on the dial but I don't know if this is normal. My first thoughts are either Crankshaft or Camshaft sensor, but I was wondering if anybody else has had this issue before and managed to sort it?
  2. Re: TDI 2.0 CFH Intermittent non-starting issue
    2009 Post(s)
    A code read first and if nothing relevant, yes crank speed sensor G28 is a known issue in this failure mode and very rarely leaves a code.
  1. Intermittent Starting Issue - Long Crank
    By acopland14 in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 11-03-2024, 06:03 PM
  2. Help 2004 1.9tdi a4 intermittent starting issue
    By Hiace2222 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-04-2019, 11:08 PM
  3. Intermittent starting issue - Polo 1.4 TDi
    By dave_tp in forum Polo - Derby - Lupo - Fox
    Last Post: 23-01-2019, 11:56 AM
  4. Intermittent starting issue
    By bigmikeyoyo in forum Golf MK5 - 2004 - 2009
    Last Post: 19-08-2016, 07:49 PM
  5. Intermittent starting issue
    By Todri in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-05-2011, 05:54 PM
