Hi All,
Our Passat threw a steady check engine light this morning. Scanned the codes at lunchtime, and found a P0111 Implauible Air Temperature code. I'm guessing this is related to my post last night about the ambient temperature reading which is currently at 60C - here. I noticed in the VCDS readout that the Climate Control module was logging a fault because of this - which we noticed...no heat from the Climate Control, unless on HI.
I've booked the car in, but this is not until next week. Can we still drive it - assume implausibility is not as bad as "does not work"? I've attached a copy of the VCDS scan (removed all the No Faults found entries to reduce space) and anonoymised the VIN.
Thanks for any pointers.
PassatB8-FaultCode.txt
