Thread: A3 2.0 TDI 170 No start
  1. A3 2.0 TDI 170 No start
    Feb 2025
    Runcorn England
    Hope someone is able to help. Car was running fine with no issues, was then left for a coupl of months. When I went back to it, it wouldn't start. Battery was fully charged, still nothing. Dahboard lights up, message says 'Igniition is on', also ABS error message.
    Have replaced battery, ignition switch, fuses, under bonnet main relay, under dash relays and Body Control Module under the dash. Any help would be greatly appreciated.
    VCDS diagnostic below.
    Code:
    Chassis Type: 8P (1K0)
    Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 47 52 56 62 72
    VIN: WAUZZZ8P7AA144642   Mileage: 196460km-122074miles
    01-Engine -- Status: Cannot be reached 1100
    03-ABS Brakes -- Status: Cannot be reached 1100
    04-Steering Angle -- Status: Cannot be reached 1100
    15-Airbags -- Status: Cannot be reached 1100
    22-AWD -- Status: Cannot be reached 1100
    44-Steering Assist -- Status: Cannot be reached 1100
    47-Sound System -- Status: OK 0000
    56-Radio -- Status: OK 0000
    Address 01: Engine
    Cannot be reached
    Address 03: ABS Brakes
    Cannot be reached
    Address 08: Auto HVAC        Labels: 8P0-820-043.lbl
       Part No SW: 8P0 820 043 BM    HW: 8P0 820 043 BM
       Component: KlimavollautomatH09 0150
       Revision: 000854      Serial number: 8P0820043BM
       Shop #: WSC 00000 000 00000
       VCID: 78A9E69BDED5D43A67B-802C
    3 Faults Found:
    01592 - Air Quality Sensor (G238)
                007 - Short to Ground
                 Freeze Frame:
                        Fault Status: 01100111
                        Fault Priority: 3
                        Fault Frequency: 254
                        Reset counter: 7
                        Mileage: 174384 km
                        Time Indication: 0
                        Date: 2021.03.31
                        Time: 17:52:12
                 Freeze Frame:
                        Temperature: 19.5°C
    00819 - High Pressure Sensor (G65)
                009 - Open or Short to Ground
                 Freeze Frame:
                        Fault Status: 01101001
                        Fault Priority: 3
                        Fault Frequency: 6
                        Reset counter: 7
                        Mileage: 196462 km
                        Time Indication: 0
                        Date: 2024.04.05
                        Time: 11:45:59
                 Freeze Frame:
                        Temperature: 15.5°C
                        Voltage: 12.00 V
                        RPM: 0 /min
                        Load: 0.0 %
                        Load: 0.0 %
    01206 - Signal for Duration of Ignition Off Time
                008 - Implausible Signal
                 Freeze Frame:
                        Fault Status: 01101000
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 7
                        Mileage: 196462 km
                        Time Indication: 0
                        Date: 2024.07.12
                        Time: 00:01:26
                 Freeze Frame:
    Address 09: Cent. Elect. (J519)       Labels:. 8P0-907-063.clb
       Part No SW: 8P0 907 063 A    HW: 8P0 907 063 A
       Component: BCM PQ35  M   105 0575
       Revision: 00105 AK
       Coding: 0E000A2FB005F0C0207041E00000015C431A29AA104DC129E40008800040
       Shop #: WSC 06314 000 00000
       VCID: 323D14B37429FE6A99F-8066
       Subsystem 1 - Part No SW: 8P2 955 119 F    HW: 8P2 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer AU350  H10 0040
       Coding: 00DD13
       Subsystem 2 - Part No: 8P0 951 177
       Component: Innenraumuebe  H04 0020
       Subsystem 3 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HO  H05 1501
       Subsystem 4 - Part No: 1K0 907 719 C
       Component: Neigungssenso  005 0003
    00778 - Steering Angle Sensor (G85)
                004 - No Signal/Communication
                 Freeze Frame:
                        Fault Status: 01100100
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 7
                        Mileage: 196462 km
                        Time Indication: 0
                        Date: 2024.07.12
                        Time: 00:02:55
                 Freeze Frame:
                            Term 15 On
                        Voltage: 12.00 V
                            ON
                            ON
                            Term 50 Off
                            OFF
                            OFF
    01309 - Power Steering Control Module (J500)
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 7
                        Mileage: 196462 km
                        Time Indication: 0
                        Date: 2024.07.12
                        Time: 00:02:55
                 Freeze Frame:
                            Term 15 On
                        Voltage: 12.00 V
                            ON
                            ON
                            Term 50 Off
                            OFF
                            OFF
    01314 - Engine Control Module
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 7
                        Mileage: 196462 km
                        Time Indication: 0
                        Date: 2024.07.12
                        Time: 00:02:55
                 Freeze Frame:
                            Term 15 On
                        Voltage: 12.00 V
                            ON
                            ON
                            Term 50 Off
                            OFF
                            OFF
    01316 - ABS Control Module
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 7
                        Mileage: 196462 km
                        Time Indication: 0
                        Date: 2024.07.12
                        Time: 00:02:55
                 Freeze Frame:
                            Term 15 On
                        Voltage: 12.00 V
                            ON
                            ON
                            Term 50 Off
                            OFF
                            OFF
    01321 - Control Module for Airbags (J234)
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 7
                        Mileage: 196462 km
                        Time Indication: 0
                        Date: 2024.07.12
                        Time: 00:02:55
                 Freeze Frame:
                            Term 15 On
                        Voltage: 12.00 V
                            ON
                            ON
                            Term 50 Off
                            OFF
                            OFF
    Address 15: Airbags
    Cannot be reached
    Address 16: Steering wheel        Labels: 8P0-953-549.lbl
       Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
       Component: J0527           H37 0070
       Coding: 0002012
       VCID: 46D55863E4A172CA257-8012
       Subsystem 1 - Part No: XXXXXXXXXXX
       Component: E0221           H04 0100
    No fault code found.
    Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
       Part No SW: 8P0 920 982 J    HW: 8P0 920 982 J
       Component: KOMBIINSTR. VDO H03 0990
       Revision: D0H03005    Serial number: 2242J005020738
       Coding: 0005428
       Shop #: WSC 12345 123 12345
       VCID: 40D94E7BC6855CFA1FB-8014
    1 Fault Found:
    00562 - Sensor for Oil Level/Temperature (G266)
                010 - Open or Short to Plus
                 Freeze Frame:
                        Fault Status: 01101010
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 7
                        Mileage: 196462 km
                        Time Indication: 0
                        Date: 2024.07.12
                        Time: 00:02:56
    Address 19: CAN Gateway        Labels:. 1K0-907-530-V4.clb
       Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
       Component: J533  Gateway   H16 0233
       Revision:   H16       Serial number: 4520K102250230
       Coding: E9827F06100202002103
       VCID: 698FB3DF957F7DB2E85-803C
    Address 22: AWD
    Cannot be reached
    Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
       Revision: D0H03005    Serial number: AUX7Z0J2FN406X
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
       Part No SW: 8P0 959 801 N    HW: 8P0 959 801 N
       Component: Tuer-SG         H04 0100
       Coding: 0000692
    Address 44: Steering Assist
    Cannot be reached
    Address 47: Sound System        Labels: 8Px-035-382.lbl
       Part No SW: 8P4 035 382 E    HW: 8P4 035 382 E
       Component: AB2 SUBWOOFERBOXH07 0180
       Revision: 00006       Serial number: 92158067869366
       VCID: 363528A39441E24AB57-8062
    Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MIN3.clb
       Part No SW: 8P0 959 802 N    HW: 8P0 959 802 N
       Coding: 0000692
       VCID: 47CB5567E3AB6BC2DE1-8012
    Address 56: Radio        Labels: 8J0-035-1xx-56.clb
       Part No SW: 8P0 035 186 S    HW: 8P0 035 186 S
       Component: R Concert2+     H03 0280
       Revision: 00H03000    Serial number: AUZ1Z3K6021148
       Coding: 0310011
       VCID: 42DD4473C8894EEA09F-8016
    Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
       Part No SW: 8P4 959 801 F    HW: 8P4 959 801 F
       Component: Tuer-SG         H04 0050
       Coding: 0000144
       Shop #: WSC 06314 000 1012544
    Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
       Part No SW: 8P4 959 802 F    HW: 8P4 959 802 F
       Coding: 0000144
       VCID: 43D34177D79347E2029-8016
    End----(Elapsed Time: 01:04, VBatt start/end: 12.0V/12.0V. VIgn 0.0V)------
  2. Re: A3 2.0 TDI 170 No start
    134 Post(s)
    2011 Post(s)
    So you have replaced relay 1 (100) with a new genuine 4H0 951 253 (644)?
  3. Re: A3 2.0 TDI 170 No start
    Feb 2025
    Runcorn England
    Yes, also 644 and 643 relays.
  4. Re: A3 2.0 TDI 170 No start
    134 Post(s)
    2011 Post(s)
    And still no ECU comms?
  5. Re: A3 2.0 TDI 170 No start
    Feb 2025
    Runcorn England
    Nothing.
    Tested fuse locations under bonnet, 13 ECU, 14 Engine Components, 15 Engine module, glow pulg, 21 Lambda probe, 22, clutch pedal switch, 23 engine relay components, 24 engine components. All show Zero voltage.
    Dash fuses 1 Dignostics/ Engine, 2 ABS, 3 Heating, 19 Quattro, 40 Starter, 41 Rear wiper. All show Zero voltage.
  6. Re: A3 2.0 TDI 170 No start
    134 Post(s)
    2011 Post(s)
    We have an almost identical 2010 Superb here with a similar issue although still running perfectly, it has the MIL on and reporting a terminal 30 error which you deal with by fitted a 644 relay to replace the 100. This worked for a few minutes but came back. I followed the wiring from fuse box to ECU plug and it was perfect, then I noticed the harness was full of water and so was the back of the ECU plug... new ECU required but obsolete! Yours MAY still be available 03L 906 022 RB at £1610.40 , second hand one coming tomorrow to check it clears the code and then try and match it to the car. Check dash side fuse 2 has ignition live and the engine bay fuse 13 also ignition live plus engine bay fuse 10 permanent live. If these are OK you need to access the ECU and cut off its chastity belt to start probing with a multimeter.
  7. Re: A3 2.0 TDI 170 No start
    Feb 2025
    Runcorn England
    Removed the fuse box, found a wire has rubbed on the battery tray and corroded through. Stripped the wiring loom insulation and it appears there is only 1 wire affected. Bits ordered, hopefull have it fixed by the end of the week.
  1. Please Help 2011 Passat DSG won't start - press brake to start message
    By bintyandthebeas in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 27-01-2023, 01:42 PM
  2. Replies: 2
    Last Post: 09-11-2020, 04:20 PM
  3. Please Help Engine Start System Fault [Access/Start Authorisation Switch (E408)]
    By norg2072 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 13-07-2020, 12:06 PM
  4. Replies: 1
    Last Post: 19-08-2019, 10:45 PM
  5. Please Help On start up intermittent glow plug flashing non start engine fault garage flashes up
    By dazcheff in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-09-2012, 08:39 PM
