Thread: Rear left door locked
Hybrid View
  1. Rear left door locked
    Feb 2025
    Italy
    Hi to all!
    Quite sure that was my fault.. I've scanned with VCDS (autoscan) and saw some errors in the rear doors, do some specific test in the section and was ok. Then I've tried to reset or do the actuator check (something similar, don't remember the exact terms..). And now the left door is locked , cannot open it. Probably some coding is missing..
    Some one can help me please? I know that I don't have to touch this.. but.. too late
  2. Re: Rear left door locked
    134 Post(s)
    2007 Post(s)
    It is not your fault, they do this right across the VW group. We did a Polo 6R a few weeks ago and it took hours to get in. We had to remove the passengers front seat (it was the front jammed) and get to the screws at the bottom of the trim, get the trim off without damage and then unbolt the regulator panel after disconnecting the widow lifter. Then our tech carefully attacked the back of the lock with a drill until he uncovered the catch and could flick it open, then fit a new lock… it took the whole day!
  1. Drivers door locked
    By bops6 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 27-02-2016, 05:43 PM
  2. HELP! door locked fast.
    By Eugheugh in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-03-2014, 04:55 PM
  3. Replies: 8
    Last Post: 19-08-2009, 09:23 PM
  4. locked door
    By fgarau in forum Bora - 1998 - 2005
    Last Post: 24-07-2008, 04:02 PM
  5. my door just stays locked
    By diljaa in forum Golf MK4 - 1999 - 2004
    Last Post: 05-12-2006, 05:48 PM
