Thread: 2008 Golf 1.9 TDI BXE Cold start issue
  1. 2008 Golf 1.9 TDI BXE Cold start issue
    Jul 2015
    Bradford
    Ive got an issue with my Golf 1.9 TDI BXE.
    First thing on a morning, it will crank but not start and have the oil pressure light come on.
    It will start with a bump start or starts without an issue when on a hill.
    anyone experienced anything like this?
    thanks
  2. Re: 2008 Golf 1.9 TDI BXE Cold start issue
    135 Post(s)
    2038 Post(s)
    The oil pressure waning is a stupid software error in the dash so indirect that, the first step is to disconnect the head harness and use a diagnostic system to establish the cranking RPM; from your description I can say it will almost certainly be below the 280 rpm minimum, also a stupid software problem.
  3. Re: 2008 Golf 1.9 TDI BXE Cold start issue
    Jul 2015
    Bradford
    I can check that with VCDS but what i don’t understand is that it started perfectly fine today when parked on a hill and after the first start the car will start perfectly fine until its been parked for 5/6hours.
  4. Re: 2008 Golf 1.9 TDI BXE Cold start issue
    135 Post(s)
    2038 Post(s)
    Could be that it was a little warmer and the oil thinner so the RPM fractionally higher, test the RPM before over thinking it.
  1. Q7 3.0TDI 2008 S-Line Keyless start issue
    By Rigy1979 in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 24-09-2018, 01:55 PM
  2. Please Help 2008 seat alhambra 2.0tdi won't start when hot only when cold
    By Squibby1 in forum Alhambra
    Last Post: 09-07-2014, 03:14 PM
  3. Cold Start Issue
    By mike_low3 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-11-2008, 02:58 PM
  4. cold start issue
    By tattooedferret in forum 80 - 90
    Last Post: 27-09-2008, 12:45 PM
  5. K-Jet Cold start issue
    By Dee-GTI in forum Golf MK2 - 1984 - 1992
    Last Post: 17-04-2008, 05:52 PM
