Thread: Sportback water in boot.
Results 1 to 10 of 12
  1. Sportback water in boot.
    Near Blackpool
    48 Post(s)
    Had everything out, side panels, bumper off, trim around the boot seal and fired ungodly amounts of weather proof sealant over and around all sorts of holes and grommets but it’s still making its way in on the drivers side, you think you’ve cured it but winter comes and it steams up when temp changes. Feel under the boot protector and the carpet does a really good job at hiding it to start with. You check for first few weeks then forget about it. Lift boot carpet and voila there’s a cm or so of water. Tried spraying hosepipe everywhere with every panel removed and I’m at a total loss. No sunroof, but has roof rails. Please tell me someone else has managed to solve this?
  2. Re: Sportback water in boot.
    2013 Post(s)
    Sunroof drains
  3. Re: Sportback water in boot.
    Near Blackpool
    48 Post(s)
    Sunroof drains
    Aye I don’t have one. Just roof rails.
  4. Re: Sportback water in boot.
    2013 Post(s)
    How about the vents behind the rear bumper? Notorious for letting water in. Revised number 3T0 819 465 A
  5. Re: Sportback water in boot.
    Near Blackpool
    48 Post(s)
    Took them out and cleaned them up, put them back in with instant gasket around them 12 months ago. Might have to try them again with all weather sealant instead. I think instant gasket prefers pressure. Or just spend £40 on new ones and no sealant
  6. Re: Sportback water in boot.
    Near Blackpool
    48 Post(s)
    Had a little further dig, once again this corner is sodden, so it’s either something higher on this side and it’s trickling down or it’s something around this vent. Bizzar, other option is to leave this bung out lol
  7. Re: Sportback water in boot.
    2013 Post(s)
    Fit the new vents and seal them in with none setting Butyl rubber mastic, this is how we do Golf 7, you can see the sealant oozing out, VW part number D469101A3, I don't know of an aftermarket alternative, it's amazing stuff.
  8. Re: Sportback water in boot.
    Jul 2008
    Norfolk
    I had the same problem, it turned out to be the rear window washer pipe was leaking, somewhere inside the rear tailgate, and was leaking water into the boot whenever i used the rear washers. It was a relatively quick fix. Good luck.
    2015 Audi A3 Sportback Sport, 2.0 TDI, S-Tronic, Shiraz Red Pete T
  9. Re: Sportback water in boot.
    2013 Post(s)
    That is the crap Valeo A3 wiper motor with the form over function spindle water jet, stupid idea.
  10. Re: Sportback water in boot.
    Near Blackpool
    48 Post(s)
    Had this a3 19 years and it’s onto its 4th valeo rear wiper motor. Shocking design.
  1. A3 Sportback boot space
    By adamsz in forum Audi A3 - 8V - 2012 - 2016
    Last Post: 13-10-2020, 11:11 PM
  2. Question Boot well full of water, boot lining not wet?
    By Lozzy90 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-08-2017, 10:35 PM
  3. S5 Sportback boot lid spoiler
    By Soot1e in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 17-03-2010, 11:16 PM
  4. Audi A3 Sportback Boot dimensions
    By madeinstein in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 17-09-2009, 02:53 PM
  5. Question A3 Sportback Water leaking into OS Footwell
    By Tom Leather in forum Audi A3 - Archive Topics
    Last Post: 08-07-2008, 09:27 PM
