Thread: 2014 VW Beetle 1.2TSI with intermittent starting issue
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. 2014 VW Beetle 1.2TSI with intermittent starting issue
    Ireland
    Good Morning All,
    My wife has a 2014 VW Beetle 1.2TSI with intermittent starting issue - Model: DBA-16CBZ 3DR AUTO - Japanese Import
    For the past 15 months or so (not long after purchased) the car has had an intermittent starting issue.
    The car cranks over no bother (good battery), but randomly wont fire.
    Notes:
    • Car seems to fire no bother from cold - Morning starts
    • Issue appears to be after car has been driven and stopped for a while - Could be temp related??
    • When car is running it runs v well , doesn't appear to be misfiring/sluggish at all, however I don't drive it much
    • There are no EML lights on the dash
    • Engine crank sensor has been replaced - Genuine VW sensor
    • Fuel Pump has been replaced - Hella Pump
    • Most recently the car has cut out twice while driving - once on Motorway
    • Key fob battery has been replaced - only 1 Key
    • Car has aftermarket Head unit and reverse camera fitted from Dealer we bought from
    Hoping to get some golden nuggets of information here
    Thanks in advance,
    Regards, Burkey
    14 1.2T Beetle 105bhp
    15 535d 313bhp
    VCDS HEX V2
  2. Re: 2014 VW Beetle 1.2TSI with intermittent starting issue
    134 Post(s)
    2009 Post(s)
    About the only part which will cause both faults is the crank speed sensor so as that is new, are there any codes stored?
  3. Re: 2014 VW Beetle 1.2TSI with intermittent starting issue
    Ireland
    Thanks for reply.
    The car was scanned with a general scanner, dont know how good that scanner was or even what make, but nothing came up.
    I have the older VAGCOM 409.1-s, but don't believe I can scan with that.
    I am getting my hands on the ross-tech Hev-V2 code reader soon. Do you think there could be code(s) stored without an EML?
    15 535d 313bhp
    VCDS HEX V2
  4. Re: 2014 VW Beetle 1.2TSI with intermittent starting issue
    Ireland
    So I ran a scan this evening using VCDS and 4 modules showed a malfunction.
    25-Immobilizer -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 1010
    09 just looks like a single fault, 19 is because there is no connection to 56, and 56 is because its an aftermarket headunit
    25 is the one that concerns me for now I think
    Cleared all DTC's and 1 module remains with a malfunction (56 Radio still displaying "cannot be reached"
    Fault from module 25 Immobilizer is below:
    1 Fault Found:
    9456681 - Key
    B104C 29 [00001000] - Implausible Signal
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 86
    Reset counter: 211
    Mileage: 145982 km
    Date: 2024.10.25.
    Time: 17:41:48
    Am I right in saying there has been 86 instances of this intermittant fault recorded?
    Side note:
    Car is starting fine the last few days. I did have a poke in around the fuse/Relay box under driver footwell the other day and just pushed in all relay/fuses to ensure they were seated correctly. There is def some bodgery in there with some wires taped up (most likely aftermarket radio/reverse camera. I also found a small 15a fuse in the footwell but cant seem to find where it goes despite having the drawings - Thats for another day
    Anyway, hope someone can assist - Is it the key emmitter or car reciever, Immobilizer or worse cluster as I have read about
    Thanks in advance
    Before clearing faults
    Code:
    Wednesday,22,January,2025,19:04:19:00009VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 24.7.1.0 (x64)
    Data version: 20240919 DS356.3
    www.Ross-Tech.com
    VIN: WVWZZZ16ZEM624837   License Plate: 141D47261
    Mileage: 148090km-92018mi   Repair Order:
    Chassis Type: 16-VW32 (6N0)
    Scan: 01 02 03 04 05 08 09 10 15 17 19 25 2B 44 56
    VIN: WVWZZZ16ZEM624837   Mileage: 148090km-92018miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    2B-Steer. Col. Lock -- Status: OK 0000
    Address 01: Engine (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
       Part No SW: 03F 906 070 CM    HW: 03F 907 309 R
       Component: SIMOS10.12AH10 5458
       Revision: --H10---    Serial number: 00000000000000 CVN: E99D14A0
       Coding: 002500D6232400081000
       Shop #: WSC 00066 000 00073
       ASAM Dataset: EV_ECM12TFS02103F906070CM 004009
       ROD: EV_ECM12TFS02103F906070AA_004_VW32.rod
       VCID: 6FED66BBB69D05EE22-803A
       VINID: 9E69EAAAA046A957460842031CF2576B76
    No fault code found.
    Readiness: 0000 0000
    Address 02: Auto Trans        Labels: 0AM-927-769.clb
       Part No SW: 0AM 300 064 G    HW: 0AM 927 769 D
       Component: GSG DSG AG7     451 5202
       Revision: 00045014    Serial number: CU502103035891
       Coding: 0000020
       Shop #: WSC 04940 001 00001
       VCID: 326BAFCFAD2F68060D-8066
    Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
       Part No SW: 5C0 907 379 C    HW: 5C0 907 379 C
       Component: ESP MK60EC1   H31 0156
       Revision: 00H31001
       Coding: F33B40F8092400FECF1302E790200080211000
       Shop #: WSC 00066 000 00000
       VCID: 2E53BBBF79174CE669-807A
    Address 05: Acc/Start Auth. (J518)       Labels:| 5K0-959-434.clb
       Part No SW: 5K0 959 434 B    HW: 5K0 959 434
       Component: VWKESSYPQ35GP 086 1101
       Revision: 00086000    Serial number: 0194133630 Dataset Number: 5C0116v____ 0001
       Coding: 030C0C
       ASAM Dataset: EV_KESSYPQ35G A02013
       ROD: EV_KESSYPQ35G_A02_VW32.rod
       VCID: 3467A9D79F3B66361F-8060
    Address 08: Auto HVAC (J255)       Labels:| 5K0-907-044.clb
       Part No SW: 5C0 907 044 P    HW: 5C0 907 044 P
       Component: Climatronic   H03 0304
       Revision: 00001K02
       Coding: 3010013002
       Shop #: WSC 00066 790 00236
       ASAM Dataset: EV_Climatronic A01010
       ROD: EV_ClimaAutoBasis_VW32.rod
       VCID: 306FA5C76B235A167B-8064
    Address 09: Cent. Elect. (J519)       Labels:. 7H0-937-08x-09.clb
       Part No SW: 7H0 937 090 C    HW: 7H0 937 090 A
       Component: BCM PQ25 Max3 H74 0712
       Revision: B8074001    Serial number: 27013233130205
       Coding: 6CB869780801080001A00F916CCB86D4F8C2670F60853901B2A0140B0000
       Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
       Component: RLS 220813 05  54  0403
       Coding: 0B300A
       Subsystem 2 - Part No SW: 6R0 959 802 BT    HW: 6R0 959 802 BT  Labels: 6R0-959-802.CLB
       Component: J386__TSG_FT  002 2661
       Serial number: KU0KU005061300014029
       Coding: 0DBC34
       Subsystem 3 - Part No SW: 6R0 959 801 BS    HW: 6R0 959 801 BS  Labels: 6R0-959-801.CLB
       Component: J387__TSG_BT  002 2661
       Serial number: KU0KU003061300016729
       Coding: 0DBC34
    1 Fault Found:
    00077 - Windshield Wiper Stop Switch (F229)
                 Freeze Frame:
                        Fault Status: 00100100
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 194
                        Mileage: 147890 km
                        Time Indication: 0
                        Date: 2019.05.29.
                        Time: 01:58:02
    Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
       Part No SW: 5C5 919 475 A    HW: 7E0 919 475 A
       Component: PARKHILFE 8K  H10 0007
       Revision: --------    Serial number: 83481326800115
       Coding: 108101
       Shop #: WSC 00066 000 00126
       ASAM Dataset: EV_EPHVA18VW3240000 001004
       ROD: EV_EPHVA18VW3240000.rod
       VCID: 3169A0C36029531E74-8064
    Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
       Part No SW: 5C0 959 655 F    HW: 5C0 959 655 F
       Component: AirbagVW10    014 0613
       Serial number: 003JQM02CUD+   Dataset Number: 5C5003v____ 0101
       Coding: 0000424C
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 356194D394417F3E28-8060
       Crash sensor for side airbag: driver side:
       Subsystem 1 - Part No SW: 5K0 959 354     HW: 5K0 959 354
       Component: S.Sens.Fahr.V  H02 ----
       Serial number: 3572MSME6E56757CZZZC
       Front Passenger's Side Airbag Crash Sensor:
       Subsystem 2 - Part No SW: 5K0 959 354     HW: 5K0 959 354
       Component: S.Sens.Beif.V  H02 ----
       Serial number: 3582MSME6656757CZZZ5
    Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
       Part No SW: 5C5 920 860 J    HW: 5C5 920 860 J
       Component: KOMBI         H30 0204
       Revision: X0030002    Serial number:
       Coding: 550A00
       ASAM Dataset: EV_KombiUDSMM9RM10 A04752
       ROD: EV_KombiUDSMM9RM10_A04_VW12.rod
    Address 19: CAN Gateway (J533)       Labels:. 6N0-909-901-6R.clb
       Part No SW: 6N0 909 901     HW: 7H0 937 090 A
       Component: GW-K-CAN TP20 H74 0712
       Revision: B8074001
       Coding: 402100
       VCID: 70EF65C7A3A31A163B-8024
    1 Fault Found:
    01304 - Radio
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 254
                        Reset counter: 218
                        Mileage: 129363 km
                        Time Indication: 0
                        Date: 2016.09.14.
                        Time: 14:40:40
    Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
       Part No SW: 5K0 953 234     HW: 5C5 920 860 J
       Component: IMMO          H30 0204
       Coding: 000007
       ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
       ROD: EV_ImmoUDSMM9RM10_VW12.rod
       VCID: 6ADB77AF8D7FE0C675-803E
    1 Fault Found:
    9456681 - Key
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 86
                        Reset counter: 211
                        Mileage: 145982 km
                        Date: 2024.10.25.
                        Time: 17:41:48
    Address 2B: Steer. Col. Lock (J764)       Labels:* 5K0-905-861.clb
       Part No SW: 5K0 905 861 C    HW: 5K0 905 861 C
       Component: ELV-PQ35      H21 0240
       Revision: 00000000    Serial number: 13000171646001
       Coding: 4900000000000000
       Shop #: WSC 00066 790 50316
       ASAM Dataset: EV_ELVMarquMPVW36X A01001
       ROD: EV_ELVMarquMPVW36X_VW32.rod
    Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 69     3501
       Revision: 00H22000
       Shop #: WSC 02069 000 90108
       VCID: 397998E370599B5ECC-806C
    Address 56: Radio
    Cannot be reached
    End-------------------------(Elapsed Time: 03:10)--------------------------
    After clearing faults
    Code:
    Wednesday,22,January,2025,21:19:55:00009VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    www.Ross-Tech.com
    56-Radio -- Status: Malfunction 0010
    Readiness: 0110 0101
       Coding: 0000020
       Revision: 00H31001
       Coding: 030C0C
       Revision: 00001K02
       Coding: 3010013002
       Coding: 0B300A
       Coding: 0DBC34
       Coding: 0DBC34
       Coding: 108101
       Coding: 0000424C
       Coding: 550A00
       Revision: B8074001
       Coding: 402100
       Coding: 000007
       Revision: 00H22000
    Address 56: Radio
    Cannot be reached
    End-------------------------(Elapsed Time: 02:58)--------------------------
    15 535d 313bhp
    VCDS HEX V2
  5. Re: 2014 VW Beetle 1.2TSI with intermittent starting issue
    134 Post(s)
    2009 Post(s)
    When it doesn't start, does it start and cut out after a second or just crank?
  6. Re: 2014 VW Beetle 1.2TSI with intermittent starting issue
    Ireland
    It just cranks. Only time it’s ever cut out was while driving and that was just twice
  7. Re: 2014 VW Beetle 1.2TSI with intermittent starting issue
    134 Post(s)
    2009 Post(s)
    Then the immobilser is not involved. Is the no start regular or random?
  8. Re: 2014 VW Beetle 1.2TSI with intermittent starting issue
    Ireland
    I would say random, but appears to show up more when engine is warm. Have had to leave car parked overnight a few times and when we return in morn it fires up right away
  9. Re: 2014 VW Beetle 1.2TSI with intermittent starting issue
    134 Post(s)
    2009 Post(s)
    You could set yourself up in a position to check the cranking RPM when it does not firse. Get it hot, put VCDS on and go into engine 01 measuring blocks 01 and look for the RPM reading, crank it over and if it doesn't start, keep cranking and wait for the ECU to reconnect and then see if you have a cranking value around 300rpm.
  10. Re: 2014 VW Beetle 1.2TSI with intermittent starting issue
    Ireland
    Yes, I understand what you mean. I will try that next time it doesn't start - Guessing you are still thinking crank speed sensor which it could be of course.
    Just out of curiosity, what does the immobilizer hold out. Ignition coil, fuel delivery etc..??
    I was also going to complete a fuel rail pressure test on VCDS (see below link) - Basically this tests to ensure pressure is increasing when engine is switched off and when the car is up to temp. Might indicate a leaking issue if not performing as expected. Do you think its worth doing this?
    - YouTube
    15 535d 313bhp
    VCDS HEX V2
  1. Please Help 2014 Skoda Octavia VRS starting issue
    By Josh98 in forum Octavia
    Last Post: 14-09-2023, 11:36 AM
  2. 2014 GTD Cold Starting Issue
    By jamie3009 in forum Golf MK7 - 2013 - 2019
    Last Post: 20-12-2018, 07:00 PM
  3. Replies: 3
    Last Post: 24-10-2017, 11:22 AM
  4. Intermittent starting issue
    By bigmikeyoyo in forum Golf MK5 - 2004 - 2009
    Last Post: 19-08-2016, 07:49 PM
  5. Intermittent starting issue
    By Todri in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-05-2011, 05:54 PM
