Thread: Confirming if your Audi Q7 4M (2016) has TPMS sensors in the valves
Results 1 to 10 of 15
  1. Confirming if your Audi Q7 4M (2016) has TPMS sensors in the valves
    Apr 2016
    berkshire
    39 Post(s)
    Heya Folks, Been a long while, and yes still have the MY17 order 2016 plated Q7, .. looks like Audi could be crumbling as more ICE cars feel the onslaught on the whole maddening EV hyper machine.
    In any, I need to go over the manual again when I find it, I was hoping if anyone on here already knew this at all?
    I am wanting to confirm if the the Audi Q7 4M 2016 has tpms chip in the valve as I want to change and move the back tyres front and the front tyres back for even wearing will this affect the car at all and also is there an easy test to determine if the car has these tps chips
    Would appreciate any pointers or if anyone has already doing this without issues
    Much appreciated
    Best Regards
    #2025
    Sent from my NE2213 using Tapatalk
  2. Re: Confirming if your Audi Q7 4M (2016) has TPMS sensors in the valves
    131 Post(s)
    1973 Post(s)
    What is the VIN? ICE's crumbling, hmm, not what the figures suggest when only 10% of private sales are EV's.
  3. Re: Confirming if your Audi Q7 4M (2016) has TPMS sensors in the valves
    Feb 2019
    MIDDLESBROUGH UK
    28 Post(s)
    Let's all keep it that way !
  4. Re: Confirming if your Audi Q7 4M (2016) has TPMS sensors in the valves
    Feb 2016
    Hungary
    116 Post(s)
    I think your car is the same as mine and mine doesn't have chips in the valves.
    I think you should look at the MMI tire pressure menu: if there is also a pressure VALUE indicated, then you have chips, but if there is only "reset", then the TPMS is based on calculation and not on actual tire pressure. However, since our cars are all-time AWD, there is no need to change tires like this, as they wear out equally. And it also depends on the specific type of tire that if you want to change it, how should you do it, right on the right side or the right rear left front and the left rear right front and so on. I think, you should ask the manufacturer or distributor about this.
    Audi Q7/4M MY2016, 3.0 TDI/200 KW Quattro
  5. Re: Confirming if your Audi Q7 4M (2016) has TPMS sensors in the valves
    Apr 2016
    berkshire
    39 Post(s)
    Quote Originally Posted by AT. View Post
    I'll check thanks.. maybe post a pic when I get later tonight
  6. Re: Confirming if your Audi Q7 4M (2016) has TPMS sensors in the valves
    Feb 2019
    MIDDLESBROUGH UK
    28 Post(s)
    Don't think it was a UK option , I fitted it aftermarket.
    If you look at the tyre valves if they have rubber stems and move then they are just plain valves.
    If they are metal and you can see a nut at the bottom these are the transmitting type for TTPS, the stems are usually silver coloured.
    Hope this helps.
  7. Re: Confirming if your Audi Q7 4M (2016) has TPMS sensors in the valves
    Apr 2016
    berkshire
    39 Post(s)
    Quote Originally Posted by mazerati View Post
    Hope this helps.
  8. Re: Confirming if your Audi Q7 4M (2016) has TPMS sensors in the valves
    131 Post(s)
    1973 Post(s)
    It has Pr:7K1 but the system I have at home doesn’t highlight the sensors part number, it would need the help of TPS or the Audi main dealer
  9. Re: Confirming if your Audi Q7 4M (2016) has TPMS sensors in the valves
    Apr 2016
    berkshire
    39 Post(s)
    Quote Originally Posted by satyp View Post
    This is what I can see .. Will check the manual shortly ..
  10. Re: Confirming if your Audi Q7 4M (2016) has TPMS sensors in the valves
    Apr 2016
    berkshire
    39 Post(s)
    Understanding this now
  1. Very strange email from Audi confirming the S6 delivery I never ordered.
    By Iannorwich in forum Audi A6 - C8 Forum - 2019 -
    Last Post: 13-11-2021, 01:20 PM
  2. Non OEM wheels/tyres needing TPMS sensors?
    By El-Cap in forum A7 - S7
    Last Post: 02-10-2016, 12:55 PM
  3. TPMS Sensors
    By apole in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 23-11-2013, 05:49 PM
  4. Aftermarket TPMS sensors
    By Quattromatt in forum A8 - S8 - V8
    Last Post: 31-05-2013, 06:26 PM
  5. Replies: 4
    Last Post: 08-05-2012, 01:21 PM
