Thread: 2.0 TDI CGLC Cam Shaft pressfit gear slipped?
  1. 2.0 TDI CGLC Cam Shaft pressfit gear slipped?
    Apr 2014
    South Africa
    My Q5 was in for its 120,000km Cam belt change service. A few days later on the first high way trip while overtaking the car goes into limp mode.
    I pulled over and turned it of and on, but would not start. Only cranks for 1 sec and then stops. Got out the laptop and VAG-COM to find this code:
    P0299 00 [01100101] - Control Range Not Reached
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 120012 km
    Date: 2025.01.20
    Time: 08:51:59
    Engine RPM: 2296.50 /min
    Normed load value: 99.6 %
    Vehicle speed: 68 km/h
    Coolant temperature: 91 °C
    Intake air temperature: 28 °C
    Ambient air pressure: 980 mbar
    Voltage terminal 30: 14.340 V
    Unlearning counter according OBD: 40
    Charge air pressure: specified value: 2550 hPa
    Charge air pressure: actual value: 1485 hPa
    Air mass: actual value (mg/stroke): 394.0 mg/stroke
    EGR Solen.val.: actual value: 99.67 %
    Throttle valve adapter: actual value: 99.99 %
    Charge air pressure actuator: acknowledgment: 84.29 %
    Mean injection quantity: 47.57 mg/stroke
    4096 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
    P0016 00 [01101101] - Incorrect Correlation
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 120012 km
    Date: 2025.01.20
    Time: 08:52:09
    Engine RPM: 887.00 /min
    Normed load value: 15.7 %
    Vehicle speed: 50 km/h
    Intake air temperature: 26 °C
    Voltage terminal 30: 12.100 V
    Engine start: start synchronization: EPM_MODE_VERIFY
    Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE: 33
    Cleared code, but car still does not start. Phone the mechanic and had the car toed in.
    I was soon phone by the mechanic and told the timing marks still line up.
    He then inspected and opted to replaced the belt, the car ran after this, but had very little power and the ECU code as that the Air Mass Filter signal was "implacable" (I don't have the exact code).
    He then decided to open the tapped cover to check for damage. The indents on the cam shaft that allow you to access the head bolt did not align with each other. (I saw it with my own eyes, was off by a small amount). There as not visual damage to the rockers (cam followers). The assumtion was that the press fit gear on the cams has rotated. (Its the gears at the back, not the one that is driven by the belt)
    He then ordered new cams, confirmed that the new shafts does indeed line up better than the old ones. Replaced both cams and the car runs fine now. No errors, lots of power.
    Is it common / possible for the press fit gear to slip?
    Is it just a coincidence that this happened less than 50km after the cam belt service?
    I want to gather information to ensure that I do not pay for something that is his fault, and if its just coincidence, then I will pay the fair fee.
  2. Re: 2.0 TDI CGLC Cam Shaft pressfit gear slipped?
    Apr 2014
    South Africa
    Here is a full scan to help identify the car after all has been fixed:
    Saturday,25,January,2025,09:42:15:28792
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
    VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.4
    Data version: 20240919 DS356.3
    Ross-Tech: Home
    Code:
    VIN: WAUZZZ8R0EA048116   License Plate: Q5
    Mileage: 120040km-74589mi   Repair Order:
    Chassis Type: 8R-AU48 (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 44 46 52 53 56 62 69 6D
              72 77 AC
    VIN: WAUZZZ8R0EA048116   Mileage: 120040km-74589miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    69-Trailer -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    AC-Reductant Control -- Status: Malfunction 0010
    Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
       Part No SW: 03L 906 018 JN    HW: 03L 906 018 JL
       Component: R4 2,0L EDC   X25 2929
       Revision: 45X25---    CVN: 7201776F38D3FF8200000000
       Coding: 2A254012243601080000
       Shop #: WSC 06208 000 00000
       ASAM Dataset: EV_ECM20TDI01103L906018JN 003003
       ROD: EV_ECM20TDI01103L906018JN.rod
       VCID: 7F5AF379A77A7B72261-802A
       VINID: 9D196AAAA2220154401080411877346143
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans (J217)       Labels:| 0B5-927-156.clb
       Part No SW: 8R1 927 156 J    HW: 0B5 927 156 K
       Component: 0B5 20 TDIRdW H02 0002
       Revision: --H02---    CVN: 00007DED
       Coding: 000001
       Shop #: WSC 06335 000 00000
       ASAM Dataset: EV_TCMDL501021 001015
       ROD: EV_TCMDL501021.rod
       VCID: 43D2BF898B12DF92029-8016
    Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
       Part No SW: 8R0 907 379 AF    HW: 8R0 907 379 AF
       Component: ESP8 quattro  H09 0030
       Revision: --------    Serial number: --------------
       Coding: 219D4C01
       VCID: 04507C95CE1C18AA7B3-8050
    Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
       Part No SW: 8K0 907 064 HG    HW: 8K0 907 064 GG
       Component: BCM2 2.0      H13 0641
       Revision: 00002001
       Coding: 01B54000000000000000
       Shop #: WSC 06335 123 12345
       VCID: 7CA00475B6EC606A033-8028
       Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
       Component: FBSAUDIB8 IDG  H71 0083
       Serial number: 0513000066896015
    Address 08: Auto HVAC (J255)       Labels: Redir Fail!
       Part No SW: 8K2 820 043 AF    HW: 8K2 820 043 AF
       Component: KLIMA 1 ZONE  H02 0123
       Revision: B0000000    Serial number: 01011020132238
       Coding: 342502E000
       Shop #: WSC 29914 001 1048576
       VCID: 6D863931FD96F9E284D-8038
    1 Fault Found:
    01274 - Air Flow Flap Positioning Motor (V71)
                001 - Upper Limit Exceeded - Intermittent
                 Freeze Frame:
                        Fault Status: 00100001
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 199
                        Mileage: 119913 km
                        Time Indication: 0
                        Date: 2025.01.15
                        Time: 12:33:43
                 Freeze Frame:
                        Voltage: 14.40 V
                        Temperature: 24.0°C
                        Temperature: 24.0°C
                        Count: 11993
                        Count: 12195
                        Bin. Bits: 01000000
                        Bin. Bits: 00000011
                        Time: 255.00 s
    Address 09: Cent. Elect. (J519)       Labels:. 8K0-907-063.clb
       Part No SW: 8K0 907 063 DG    HW: 8K0 907 063 DG
       Component: BCM1 1.0      H16 0103
       Revision: 07016001    Serial number: 00000051608701
       Coding: 2600C0108034AFC00081400000001D0D0F1D670827090201000004004401030100000024000000
       VCID: 77AA1B598FCA43326E1-8022
       Subsystem 1 - Part No SW: 8R2 955 119 A    HW: 8R2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS416 130910  H11 0050
       Serial number: 90243015130829073654
       Coding: 01DD13
       Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
       Component: G397_RLFS  H06 0002
       Serial number: 21799078
       Coding: 02005C
       Subsystem 3 - Part No SW: 8K0 941 531 AS    HW: 8K0 941 531 AS
       Component: E1 - LDS  H03 0031
       Serial number: 00000000002709130202
       Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
       Component: Humidity_Sens  H03 0002
       Serial number: 8D99CEC6000000000001
    Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
       Part No SW: 8R0 959 655 G    HW: 8R0 959 655 G
       Component: AirbagVW-AU10 H47 0610
       Serial number: 003JPDB0RU76   Dataset Number: 8R0909602E  0010
       Coding: 30473431313030303030554A305238523053
       ASAM Dataset: EV_AirbaAU10SMEAU416 002004
       ROD: EV_AirbaAU10SMEAU416.rod
       VCID: 48C8A8A5B234FCCAD7B-801C
       Crash sensor for side airbag: driver side:
       Serial number: 6334MSME7F344652J
       Front Passenger's Side Airbag Crash Sensor:
       Serial number: 6344MSME7F06352AM
       Rear Side Airbag Crash Sensor (on driver's side):
       Serial number: 6352QSME3C372F44R
       Passenger side rear thorax airbag crash sensor:
       Serial number: 6362QSME303504520
       Crash sensor for front airbag: driver side:
       Serial number: 63732SME1136417CY
       Crash sensor for front airbag: front passenger side:
       Serial number: 63832SME1136454C-
    Address 16: Steering wheel (J527)       Labels:. 8K0-953-568.clb
       Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
       Component: Lenks.Modul   H03 0003
       Revision: C0062331    Serial number: 90862MJ50001F
       Coding: 000037
       VCID: 48C8A8A5B2B4FCCAD7B-801C
       Component: E221 - MFL  H03 0004
    Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
       Part No SW: 8R0 920 901 B    HW: 8R0 920 901 B
       Component: KOMBIINSTR.   H07 0563
       Revision: 00400000    Serial number: WX222YY9E
       Coding: 338622000301000C010000
       VCID: 313EE541212E5D02E05-8064
    Address 19: CAN Gateway (J533)       Labels:. 8T0-907-468.clb
       Part No SW: 8R0 907 468 L    HW: 8R0 907 468 A
       Component: GW-BEM 5CAN   H11 0056
       Revision: 1V080027    Serial number: 2741V139130250
       Coding: 80CF07FF00
       Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
       Component: J367-BDM  H07 0141
       Serial number: 40268H14421461152159
       Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
       Component: J532_DCDCStab  H05 0006
       Serial number: 13273000461011200410
    Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
       Part No SW: 8T0 035 785 A    HW: 8T0 035 785
       Component: SG ext.Player H08 0290
       Revision: 00000000
       Coding: 020202
       VCID: 392EDD61F95E9542585-806C
    Address 42: Door Elect, Driver (J386)       Labels:. 8K0-959-793.clb
       Part No SW: 8K0 959 793 R    HW: 8K0 959 793 P
       Component: TSG FA        H02 0510
       Revision:             Serial number: 0000077230979
       Coding: 011D02204001440004
       VCID: 4FFA83B957DA2BF2961-801A
    Address 44: Steering Assist (J500)       Labels:| 8K0-909-144.clb
       Part No SW: 8R0 909 144 F    HW: 8R0 909 144 B
       Component: RCEPS         H38 0507
       Revision: 00001000    Serial number: 0030909860 Dataset Number: 8R0909852H  0021
       Coding: 100000000001
       Shop #: WSC 06334 000 00000
       ASAM Dataset: EV_RCEPSAU48X 008014
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 3B22C769F3E2A7524A9-806E
    1 Fault Found:
    2306 - Function Restriction due to Start Voltage Interruption
              U1410 00 [00001000] - -
              [Funktionseinschränkung der Lenkung durch Spannungseinbruch bei hoher Geschwindigkeit]
              Intermittent - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 204
                        Mileage: 120012 km
                        Date: 2025.01.20
                        Time: 08:52:08
                        Write only channel
    Address 46: Central Conv. (J393)       Labels:. 8K0-907-064-46.clb
       Revision: 00002001    Serial number: 0317095108
       Coding: 013A0622A0B930008520053680040047
       Subsystem 1 - Part No: 8K0 951 177
       Component: DWA-Sensor  H02 0040
       Subsystem 2 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HO  H05 1501
    Address 52: Door Elect, Pass. (J387)       Labels:. 8K0-959-792.clb
       Part No SW: 8K0 959 792 R    HW: 8K0 959 792 P
       Component: TSG BF        H02 0510
       Revision:             Serial number: 0000076801242
       VCID: 4EC49EBD50D022FA9D7-801A
    Address 53: Parking Brake (----)       Labels: 8K0-907-801-V2.clb
       Part No SW: 8K0 907 801 M    HW: 8K0 907 801 J
       Component: EPB-4         H01 0004
       Revision: --------    Serial number: 30000000109274 Dataset Number: 8R0909522A  0002
       ASAM Dataset: EV_ParkiBrake 001028
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 392EDD61F9DE9542585-806C
    Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
       Part No SW: 8R2 035 186 N    HW: 8R2 035 186 N
       Component: Concert3      H05 0470
       Revision: 00000002    Serial number: AUZ5Z6M1950486
       Coding: 0400048204058D00415B071800
       VCID: 41DEB581918ECD82105-8014
       Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
       Component: Display
    1 Fault Found:
    03157 - Functionality limited due to Communications Disruption
                000 - - - Intermittent
                 Freeze Frame:
                        Fault Status: 00100000
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 208
                        Mileage: 120012 km
                        Time Indication: 0
                        Date: 2025.01.20
                        Time: 17:18:03
                 Freeze Frame:
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 10000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
    Address 62: Door, Rear Left (J388)       Labels:. 8K0-959-795.clb
       Part No SW: 8K0 959 795 G    HW: 8K0 959 795 D
       Component: TSG HL        H01 0510
       Revision:             Serial number: 0000077133118
       Coding: 010C02204001240004
       VCID: 46D4A69DB8A0EABA257-8012
    Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
       Part No SW: 8K0 907 383 D    HW: 8K0 907 383 D
       Component: Anhaenger     H09 0100
       Revision: 1G001001    Serial number: 00000194377818
       Coding: 0109080000000000
       Shop #: WSC 25397 000 00000
       VCID: 3536D151D5467122BCD-8060
    Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
       Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
       Component: J605  Master  H52 0330
       Revision: --------    Serial number: 8R0827851B
       VCID: 3B22C769F362A7524A9-806E
       Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
       Component: J756  Slave  H52 0330
       Serial number: 8R0827852B
    Address 72: Door, Rear Right (J389)       Labels:. 8K0-959-795.clb
       Component: TSG HR        H01 0510
       Revision:             Serial number: 0000077132962
    Address 77: Telephone        Labels: 8P0-862-335.lbl
       Part No SW: 8T0 862 335 F    HW: 8T0 862 335 E
       Component: FSE_256x BT     H45 0660
       Revision: 00000000    Serial number: 00000005679323
       Coding: 0010390
       VCID: 3D26C971E176A96274D-8068
    Address AC: Reductant Control (J880)       Labels: 4G0-907-355.clb
       Part No SW: 4G0 907 355 C    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H09 0010
       Revision: 00000000    Serial number: 132540058 Dataset Number: 8R0909571D  0014
       ASAM Dataset: EV_RDCMA00100 008040
       ROD: EV_RDCMA00100.rod
       VCID: 2B02F729038237D2DA9-807E
    1 Fault Found:
    196867 - Control Circuit for Reductant Pump 1
              P208A 00 [00001001] - Open Circuit
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 167
                        Mileage: 120038 km
                        Date: 2025.01.23
                        Time: 17:53:51
                        Voltage terminal 30A: 14.3 V
                        Voltage terminal 30B: 14.3 V
                        Voltage terminal 87: 14.2 V
                        Reductant_pwm_duty_cycle: 0.0 %
                        Reductant_speed_pump_motor: 0 /min
                        Reductant_pump_output_stage_temperature: 34 °C
                        Reductant_heater_control_1_output_stage_temperature: 35 °C
                        Reductant_tank_temperature_sensor_actual_value: 27 °C
                        Reductant_temperature_ambient: 26 °C
                        Reductant_current_pump_motor_A: 0.0 A
                        Reductant_current_pump_motor_B: 0.0 A
                        Reductant_current_pump_motor_C: 0.0 A
                        Reductant_heater_control_1_actual_power_value: 0.0 A
                        Reductant_heater_control_2_actual_power_value: 0.0 A
                        Reductant_transfer_pump_current: 0.0 A
                        Reductant_pressure_sensor_actual_value: -50 mbar
                        Reductant_voltage_sensor_supply: 4.9 V
                        Reductant_voltage_sensor_gnd: 0.0 V
                        Reductant_level_sensor_actual_raw_voltage: 0.5 V
                        KL15 on: On
                        DIAG_Opt_H: On
                        Tank_L_SC: OFF
                        Lines_L_SC: OFF
                        DIAG_Lines_H: On
                        DIAG_Lines_L: On
                        DIAG_Tank_H: On
                        DIAG_Tank_L: On
                        MO_SCR_Dosierpumpe_Zustand: 00
                        MO_SCR_Tankheizung: OFF
                        MO_SCR_Leitungsheizung: OFF
                        MO_SCR_Transferpumpe: OFF
                        reserviert 1 0: On
                        Reserviert 2: OFF
                        Can signal MO_SCR_Dosierpumpe_Soll: 0.0 %
    End----------(Elapsed Time: 01:45, VBatt start/end: 12.2V/12.2V)-----------
  3. Re: 2.0 TDI CGLC Cam Shaft pressfit gear slipped?
    131 Post(s)
    1974 Post(s)
    I haven’t come across this for years, it used to happen on the V6 TDI, the cams have not changed part number and I am not aware of a TPI about it so must be a rare quality control failure HOWEVER they are available aftermarket from multiple sources such as Febi so that is telling.
  4. Re: 2.0 TDI CGLC Cam Shaft pressfit gear slipped?
    Apr 2014
    South Africa
    I havenÂ’t come across this for years, it used to happen on the V6 TDI
    Thank you for the reply.
    I'm trying to assess what is the odds of this happening 50km after a timing job (at no fault of the guy that installed the belt).
    vs
    What is the odds of the belt skipping a tooth and causing this gear to slip on the shaft, but not break / damage the valves or rockers.
    I'm leaning towards this is just my bad luck / coincidence that it happened. (Unless there something that a mechanic could over/under torque during the cam belt procedure that would induce this failure)
    The fault code indicated that the two sensors are reading out of sync. Is the cam sensor on the "exhaust" cam that is driven by the belt or on the "inlet" cam that is driven with this rear side gear?
    My reasoning is if its on the exhaust cam that is driven with the tooth belt the error code can only be a result of incorrect timing marks/belt.
    If the sensor is on the intake cam then it could still be out of sync even if the belt is 100% correctly timed. Thus the gear slipped by no fault of the mechanic.
  5. Re: 2.0 TDI CGLC Cam Shaft pressfit gear slipped?
    131 Post(s)
    1974 Post(s)
    There is nothing a mechanic could do after 1 klick never mind 50k.
  1. Question CGLC faulty Egt sensor 1 replacement
    By Sivvy in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 26-10-2022, 09:52 AM
  2. BRD gear driven balance shaft delete
    By Calasp in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 01-09-2019, 06:03 PM
  3. Question A6 C7 2.0 TDI CGLC Dipstick required
    By ollysteve in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 29-01-2016, 05:37 PM
  4. 1.4 Gear Knob - Wide Shaft
    By DJC in forum Golf MK4 - 1999 - 2004
    Last Post: 23-05-2013, 04:53 PM
  5. Gear selector shaft oil seal
    By waynetdi130 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-03-2009, 12:47 AM
