Thread: EPB Auto Hold not working
  1. EPB Auto Hold not working
    Dec 2012
    Skelton - saltburn by the Sea
    H
    Have a yellow warning light on my dash a P with a dash across it, I think it come on after disconecting the battery, also the Auto Hold on EPB switch is not now working, it has had a new Clutch master cylinder fitted, but warning light was on before that was fitted .
    Scan today
    Address 53: Parking Brake Labels: 3AA-907-801.clb
    Part No SW: 3AA 907 801 E HW: 3AA 907 801 E
    Component: J540 EPB4 VW-55183 0007
    1 Fault Found:
    03182 - Clutch Position Sensor (G476)
    010 - Open or Short to Plus
    Freeze Frame:
    Fault Status: 01111010
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 13
    Mileage: 196338 km
    Time Indication: 0
    Date: 2019.05.28
    Time: 15:17:50
    Freeze Frame:
    Voltage: 12.20 V
    Count: 55
  2. Re: EPB Auto Hold not working
    Jan 2008
    Cornwall
    You'll need to fix the clutch position sensor fault, as a signal from this sensor is used in the auto hold system. Even if there is another cause, this one will affect the system.
    I should add, that if you look at the switch signal in either measuring blocks or advance measurements, you will be able to determine if the switch itself is sending a signal.
  1. Auto-Maybe-Hold
    By bobwmac in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-11-2010, 09:42 PM
  2. Important AUTO HOLD anyone?
    By patomlin76 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-08-2010, 06:39 PM
  3. auto hold
    By villager in forum Passat CC
    Last Post: 13-05-2010, 09:50 AM
  4. Auto hold - how does it think?
    By lemmylemmy in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-04-2010, 09:12 AM
  5. Auto hold
    By Scott23 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-09-2009, 08:43 PM
