Thread: Passat B8.5 estate water ingress rear doors
  1. Passat B8.5 estate water ingress rear doors
    Aug 2007
    Hi guys n gals,
    Recently purchased a 15 plate Passat GT estate and have found the passenger rear floor full of water, at first I thought it was coming in through the bulkhead, but have since discovered when we have heavy rain it's filling the door up and running over the door skin and in through the door panel, and for the life of me can't see any drain holes in the door.
    Are there any? are they in the seals or have I missed something obvious?
    Thanks all
  2. Re: Passat B8.5 estate water ingress rear doors
    135 Post(s)
    2039 Post(s)
    Not something I have encountered, what is the VIN?
  3. Re: Passat B8.5 estate water ingress rear doors
    Aug 2007
    Hiya
    Vin is WVWZZZ3CZGE043234
    The only other info I've found online is this video on youtube
    - YouTube
    Which mentions the leak in the rear door, but not how to sort it or where the drain holes actually are.
    thanks again for the reply
  4. Re: Passat B8.5 estate water ingress rear doors
    135 Post(s)
    2039 Post(s)
    My initial suspicion would be the rear vents behind the sides of the rear bumper, these have been revised twice since your car was made to new number 6R0 819 465 C and £26.94 retail inc. each. Yes, they are the same as a Polo. The other door seal has also been revised but I need to look that up at work. It would be worth removing the door cards and having someone spray water around the door and look for leaks such as from the speaker pods.
  5. Re: Passat B8.5 estate water ingress rear doors
    Aug 2007
    I've just bought a UV torch and some dye on the advice of a mechanic I know and am planning to give that a whirl. I'll try with the door first as it's the easiest, I just don't know how to solve it if it is the door, there must be water drain holes though surely?
    I'll be honest, I hadn't really heard anything about the body vents until recently & assumed they would just let water into the boot, can they let water into the footwell without the boot getting wet? it may sound a daft question but just trying to rule things out.
    Don't know if this makes any difference but my wife only uses the car and we noticed it initially after the car had been parked up for a few weeks and we'd had a lot of rain
  1. Replies: 0
    Last Post: 02-08-2021, 09:12 PM
  2. Passat water ingress ??
    By tinkerbell in forum New Member Introductions
    Last Post: 16-02-2010, 04:58 PM
  3. Please Help Water ingress - rear near side
    By l33boy in forum Bora - 1998 - 2005
    Last Post: 19-01-2010, 02:17 PM
  4. VW Passat 130 TDi Water Ingress What to do
    By ukdiesel in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-02-2008, 01:35 PM
  5. 1999 passat water ingress
    By theglobetroter in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-01-2008, 10:36 PM
