Thread: 2014 2L TFSI Idle fault
  1. 2014 2L TFSI Idle fault
    Jan 2012
    Sandhurst
    Hi
    I have an Audi A4 Avant 2L TFSI Quattro - CDNC engine and its developed a fault causing a terrible idle and EML light.
    Scanned with VCDS and there are 7 faults in the engine:
    Code:
                    Address 01: Engine       Labels: 06H-907-115-CDN.clb
    Control Module Part Number: 8K5 907 115 H    HW: 8K2 907 115 L
      Component and/or Version: 2.0l R4/4V TF H09 0004
               Software Coding: 12250013244601022000
                Work Shop Code: WSC 38633 001 1048576
                  ASAM Dataset: EV_ECM20TFS0118K5907115H 001006 (AU48)
                           ROD: EV_ECM20TFS0118K5907115H.rod
                          VCID: 372B2BC12FCE7A62FE1-8062
    7 Faults Found:
    5646 - Leak in Air Intake System
              P2279 00 [109] - -
              Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 89159 km
                        Date: 2024.11.11
                        Time: 20:20:33
                        Engine RPM: 1082.50 /min
                        Normed load value: 7.1 %
                        Vehicle speed: 0 km/h
                        Coolant temperature: 86 °C
                        Intake air temperature: 25 °C
                        Ambient air pressure: 1010 mbar
                        Voltage terminal 30: 14.465 V
                        Unlearning counter according OBD: 40
                        Mean injection time: 1.390 ms
                        Engine operating condition: Idle
                        Engine operating condition-Test_Program_Channel 87: 5
                        Driver-side belt buckle status-Bits 0-7: 77
                        Engine torque: 14.1 Nm
    4007 - Idle Control System RPM
              P0507 00 [032] - Higher than Expected.
              Intermittent - Not Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 89159 km
                        Date: 2024.11.11
                        Time: 20:20:32
                        Engine RPM: 1166.50 /min
                        Normed load value: 6.3 %
                        Coolant temperature: 92 °C
                        Intake air temperature: 45 °C
                        Voltage terminal 30: 13.169 V
                        Unlearning counter according OBD: 37
                        Mean injection time: 1.344 ms
                        Driver-side belt buckle status-Bits 0-7: 32
                        Engine torque: 13.0 Nm
    10203 - Random/Multiple Cylinder Misfire Detected
              P0300 00 [039] - -
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 89200 km
                        Date: 2024.11.12
                        Time: 17:37:26
                        Engine RPM: 730.00 /min
                        Normed load value: 10.2 %
                        Coolant temperature: 67 °C
                        Intake air temperature: 41 °C
                        Voltage terminal 30: 14.041 V
                        Unlearning counter according OBD: 80
                        Mean injection time: 1.571 ms
    10593 - Cylinder 3
              P0303 00 [039] - Misfire Detected
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 89200 km
                        Date: 2024.11.12
                        Time: 17:38:46
                        Engine RPM: 727.50 /min
                        Normed load value: 10.6 %
                        Coolant temperature: 75 °C
                        Intake air temperature: 37 °C
                        Voltage terminal 30: 14.300 V
                        Mean injection time: 1.626 ms
    10594 - Cylinder 4
              P0304 00 [039] - Misfire Detected
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 89200 km
                        Date: 2024.11.12
                        Time: 17:37:26
                        Engine RPM: 706.00 /min
                        Voltage terminal 30: 14.112 V
                        Mean injection time: 1.598 ms
    10592 - Cylinder 2
              P0302 00 [039] - Misfire Detected
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 89200 km
                        Date: 2024.11.12
                        Time: 17:37:26
    4105 - Bank 1; System too Lean at Idle
              P2187 00 [237] - -
              MIL ON - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 89187 km
                        Date: 2024.11.12
                        Time: 15:31:18
                        Engine RPM: 848.50 /min
                        Normed load value: 8.2 %
                        Vehicle speed: 1 km/h
                        Coolant temperature: 90 °C
                        Intake air temperature: 36 °C
                        Voltage terminal 30: 14.229 V
                        Mean injection time: 1.559 ms
                        Driver-side belt buckle status-Bits 0-7: 112
                        Engine torque: 20.8 Nm
    Seems its obviously a an air leak somewhere? Had a look around all the hoses I can see for anything obvious but couldn't see anything. The idle is really rough but revs seemingly cleanly enough.
    Any tips to aid diagnosis would be great
    Adam
  2. Re: 2014 2L TFSI Idle fault
    2005 Post(s)
    Disconnect the cam cover breather vent hose from the inlet manifold and allow it to breath to atmosphere, externally cap (there is a strong vacuum) the port on the inlet manifold. If this stops the poor running, fit a new breather unit. If this is left a long time it cam damage the crank front and rear seals plus suck in the chain cover gasket.
  3. Re: 2014 2L TFSI Idle fault
    Jan 2012
    Sandhurst
    Thanks Crasher, will give it a go
  4. Re: 2014 2L TFSI Idle fault
    Jan 2012
    Sandhurst
    followed the instructions, pointed to the PCV, replaced that and all is well again. Many thanks
  1. Please Help 2014 A4 1.8L TFSI CJEB diesel type rattle sound at low rpms
    By Diamondstar693 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-11-2021, 08:44 PM
  2. 2.0 TFSI BWA Idle problem
    By Turbo Lee in forum 2.0T, TSI and TFSI - Engine
    Last Post: 21-08-2014, 08:22 PM
  3. Query - 2014 Audi Tt Sport Tfsi Coupe, 1798CC Petrol, 2DR, Auto
    By haux in forum TT - TT RS - 8J Forum - 2006- 2014
    Last Post: 08-07-2014, 07:27 AM
  4. A4b8 tfsi very rough idle and more!
    By mrsmythe1 in forum 2.0T, TSI and TFSI - Engine
    Last Post: 29-10-2013, 11:21 PM
  5. 1.8 TFSi Noisy at idle [Video]
    By Nano Jake in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 05-06-2009, 11:31 PM
