Thread: G12 Evo compatible with G12
  1. G12 Evo compatible with G12
    Mike McKinstry Guest
    Presume if I buy ready mixed G12 evo this can be readily used in older 2013 passat which used to have g12 and the g12 Evo will replace G13 LL ok.
    Sorry as Im sure been asked before.
  2. Re: G12 Evo compatible with G12
    134 Post(s)
    2003 Post(s)
    If it is given a good flush and blow clear to remove as much trace of tap water as possible, then fine. On sensitive cars like MQB platform we even fill with distilled water and blow through again to get as much out as possible.
  3. Re: G12 Evo compatible with G12
    Went to get G13 at Vw today they only sell G12 evo apparently so will it be ok to mix or not especially if not draining system ?
  4. Re: G12 Evo compatible with G12
    134 Post(s)
    2003 Post(s)
    With the MQB heater matrix I would get as much G13 and possible tap water out of there as possible.
  5. Re: G12 Evo compatible with G12
    But I’d be better to top up with G12evo than ready mixed G13 ??
    Or continue topping up G13 with r/mixed G13 then swap the log of g12 evo with a flush .
    Hoping that’s right .
    Don’t think g12evo and g13 will turn coolant brown either ??
  6. Re: G12 Evo compatible with G12
    134 Post(s)
    2003 Post(s)
    Should be OK, I just don't like mixing fluids.
  1. Compatible cd HU
    By Tobyone in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-10-2011, 11:27 AM
  2. Question Are these compatible with my car.........
    By smoggyrich in forum Golf MK5 - 2004 - 2009
    Last Post: 17-08-2011, 04:24 PM
  3. AMI Compatible Disks
    By passing in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 08-01-2009, 06:24 PM
  4. A5 with bluetooth car kit compatible 3g
    By jlouette in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 05-11-2008, 09:46 PM
