Thread: P0123 code and flashing glow plug light
  1. P0123 code and flashing glow plug light
    Sep 2023
    GB
    Hi all
    Hoping someone can help me.....
    Recently did a couple of things in the engine bay and after I seemed to have developed a couple of faults, one was the fuel temp sensor and the other was the above, throttle body signal too high. Thought I had nicked a couple of cables when I was working in the engine bay so set out to figure which. Turns out it was just the connector on the fuel temp sensor, but the other fault didn't go away.
    I have checked the signal ref pin and it has 5v, ground pin and this has 0v, checked the motor for the butterfly works when I connect 12v across pins 4 and 5, even spliced into the wire coming out of pin 2 which is the signal back to the ECU and this has voltage.
    Also decided to do a continuity check down the loom back to the ecu and that all checked out.
    Then got a replacement butterfly valve body I had spare and plugged it in but still came up with the above fault code.
    I had taken the original off to clean it and I have read somewhere that you would need to do an adaption with vagcom and that will clear it, is this true? Does anyone know the procedure to do this? Anyone with vagcom in Down or Armagh?
    Any help will be greatly appreciated.
    Sent from my SM-S911B using Tapatalk
  2. Re: P0123 code and flashing glow plug light
    134 Post(s)
    1994 Post(s)
    16507 (P0123) - Throttle Position Sensor(G69): Signal too High
    What is the VIN?
  3. Re: P0123 code and flashing glow plug light
    Sep 2023
    GB
    WVGZZZ1TZCW091497
    Thanks Crasher
  4. Re: P0123 code and flashing glow plug light
    134 Post(s)
    1994 Post(s)
    Remind me tomorrow
  5. Re: P0123 code and flashing glow plug light
    Sep 2023
    GB
    Hi Crasher was this a problem you have come across before?
  6. Re: P0123 code and flashing glow plug light
    134 Post(s)
    1994 Post(s)
    Quote Originally Posted by adspynappels View Post
    Yes, it was a faulty ECU, water damage. The throttle body should be 03L 128 063 T. We had a Golf 6 in last week with this, we fitted a new Hitachi body a year ago and the code came back, we took it off to fit a new one under warranty and it was completely blocked with crud, unbelievable for a year. We haven't returned the new one yet but it has been a week. No, they don't need adapting even though some manufacturers say they do. You can check its operation in basic settings.
  1. Start stop system fault Audi A3 glow plug light flashing no error code
    By kumitsu in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 07-05-2023, 05:30 PM
  2. Question Passat Alltrack 2013 yellow Glow Plug flashing Light Snap On Code P253500
    By burnseyman151 in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 18-11-2019, 09:42 PM
  3. Question Passat Alltrack 2013 yellow Glow Plug flashing Light Snap On Code P253500
    By burnseyman151 in forum Forum support and issues
  4. Replies: 2
    Last Post: 29-08-2018, 06:05 PM
  5. Fault Code p0200 (flashing glow plug)
    By s0niX in forum Polo - Derby - Lupo - Fox
    Last Post: 24-04-2007, 05:32 PM
