Thread: Q3 quattro front lower wishbone
  1. Q3 quattro front lower wishbone
    Oct 2023
    near Letham Fife
    Hi All,
    Looking for info re the removal of the nearside front wishbone. The auto gearbox blocks easy access to the front bush bolt. I think the sub frame may need to be lower to access.
    The reason for the removal require to change rear bushes which are worn MOT advisory. Nothing mention in Audi removal guide.
    Thoughts and replies welcomed.
    Kenny
    Vehicle is Audi Q3 quattro 2014 2.0 l diesel auto 177hp.
  2. Re: Q3 quattro front lower wishbone
    135 Post(s)
    2026 Post(s)
    You fit special alignment retaining pins into the front and rear consul bracket holes one one bolt in each is removed and then drop the consuls out and work on them on the bench.
  3. Re: Q3 quattro front lower wishbone
    Oct 2023
    near Letham Fife
    Thanks for the reply,
    I removed the offside arm but did not use the special and do not have them. I have not removed the nearside due to the gearbox restricting access.
    At first I could not remove the arm from the ball joint after unscrewing the 3 nuts it was very tight. I did get it off and replaced the worn rear bush bracket but cannot refit the arm onto the ball joint as the hub has moved.
    I have 2 questions
    Is it possible for the wrong size of arm be fitted ?
    Is there dimensions available for the arm?
    Here are the dimensions from the arm I removed distance between both bushes 360mm, distance between bush and ball joint 390mm.
    I obtained the following part no from an Audi dealership as 3C0 407 151 G.
    Here is the chassis no WAUZZZ8U5ER146533 Audi Q3 S line quattro 2.0 auto
    I have confirm part is correct and the original arms are correct. So I have answered the above questions myself.
  4. Re: Q3 quattro front lower wishbone
    Oct 2023
    near Letham Fife
    Looking for a measurement of 'a' top of wheel arch to center of wheel to compare against mine.
    Audi Q3 2.0 TDi quattro, standard suspension. 18" rims tyres 235/50/R18.
    Kenny
  5. Re: Q3 quattro front lower wishbone
    Oct 2023
    near Letham Fife
    How often do the control bracket rubbers on the front susp'n arms wear out ?
    The reason I'm asking this is the 2nd set of arms replaced on this Q3. First occurred at 40, 000 miles now at 80,000 miles.
    Will be getting the steering and suspension geometry check very soon.
    Thoughts and experiences please.
    Kenny
  6. Re: Q3 quattro front lower wishbone
    135 Post(s)
    2026 Post(s)
    They are very failure prone right across the PQ35and PQ46 platforms so we recommend our customers have Powerflex which are fit and forget.
  7. Re: Q3 quattro front lower wishbone
    Oct 2023
    near Letham Fife
    Oh What a surprise.
    Thanks for the link, will bear it in mind for the next time.
    Kenny
  1. Question Front Near Side Lower Wishbone Replacement, DSG Gearbox !
    By chesterman in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-06-2017, 01:40 PM
  2. Snow + hill + Skid = snapped lower wishbone and deployment of both from airbags
    By Jackblack in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 26-01-2016, 11:12 PM
  3. OSF lower front wishbone replacement
    By wigs_1 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-04-2013, 09:00 PM
  4. 3.2 quattro wishbone
    By lcbandit in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 20-02-2012, 12:51 PM
  5. Front lower wishbone rear bushes
    By Pezza in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 14-07-2010, 04:53 PM
