Thread: Transmission fault code. A6 C7 3.0 TDI S-Tronic
  1. Transmission fault code. A6 C7 3.0 TDI S-Tronic
    Mar 2014
    Aylesbury Bucks
    21 Post(s)
    A few days ago my wife started the car, and a warning came up of a transmission fault, and not to drive. This reset on restart, and has been fine ever since.
    Below is a complete scan, and the transmission module is showing a 'locked' fault code, which is component protection. No modules in the car have ever been replaced, the only thing done was the addition of a trailer module, and correct recoding of other modules some 8 years ago.
    Has anyone had this before? Luckily, the fault appears to be electrical, not a mechanical fault inside the transmission. Hopefully!
    Code:
    Saturday,12,October,2024,11:05:00:52594
    VCDS Version: 24.7.0.0 (x64)  HEX-V2 CB: 0.4643.4
    Data version: 20240715 DS356.3
    Ross-Tech: Home
    VIN:
    Code:
    WAUZZZ4G3EN090454
    Mileage: 168756km-104860mi   Repair Order:
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 55 56 5F
              62 69 6D 72
    I
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: Malfunction 0010
    05-Acc/Start Auth. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    3B-Sensor Elect. -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    69-Trailer -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    Address 01: Engine (J623-CDUD)       Labels:. 059-907-401-V2.clb
       Part No SW: 4G0 907 401 Q    HW: 4G0 907 401
       Component: 3.0TDI EDC17  H41 0002
       Revision: 53H41---    CVN: A07A8DF1
       Coding: 12254012053601020000
       Shop #: WSC 02391 785 00200
       ASAM Dataset: EV_ECM30TDI0114G0907401Q 001003
       ROD: EV_ECM30TDI0114G0907401Q.rod
       VCID: 313C1CA2E1A58DA2E0D-8064
       VINID: 9D196AAAA1170D578024010510874AA139
    3 Faults Found:
    4481 - Cruise Control Switch (E45)
              P0568 00 [00100000] - Implausible Signal
              Intermittent - Not Confirmed - Tested Since Memory Clear
    17403 - Implausible Data Received from Parking Brake Control Module
              U0417 00 [00100000] - -
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 168075 km
                        Date: 2024.09.23
                        Time: 14:32:10
                        Engine RPM: 969.00 /min
                        Normed load value: 41.6 %
                        Vehicle speed: 0 km/h
                        Coolant temperature: 32 °C
                        Intake air temperature: 18 °C
                        Ambient air pressure: 980 mbar
                        Voltage terminal 30: 12.700 V
                        Unlearning counter according OBD: 15
                        Limitation: accelerator pedal: 81.7 Nm
                        CAN status - engine control module-Bits 0-7: 0
                        Cruise Control System (CCS): status-Bits 0-7: 44
                        CAN status - transmission control module-Bits 0-7: 0
                        CAN status - brake control module 1-Bits 0-7: 0
                        CAN status - brake control module 2-Bits 0-7: 0
                        selected gear-Bits 0-7: 255
    5523 - Engine Start Blocked by Immobilizer
              P1570 00 [00100000] - -
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 168673 km
                        Date: 2024.10.09
                        Time: 09:59:55
                        Engine RPM: 811.50 /min
                        Normed load value: 0.0 %
                        Coolant temperature: 70 °C
                        Ambient air pressure: 970 mbar
                        Voltage terminal 30: 11.800 V
                        Unlearning counter according OBD: 37
                        Immobilizer snapshot A-Sia Error Snap A: 1D 1D 8F
                        Immobilizer snapshot B-Sia Error Snap B: 0A 00 00
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans (J217)       Labels:| 0B5-927-156.clb
       Part No SW: 4G2 927 156 P    HW: 0B5 927 156 K
       Component: 0B5 30 TDIRdW H02 0003
       Revision: --H02---    CVN: 0000094C
       Coding: 000001
       ASAM Dataset: EV_TCMDL501021 001015
       ROD: EV_TCMDL501021.rod
       VCID: 3B203E8A33E977F24A1-806E
    1 Fault Found:
    7971 - Transmission Control Unit
              P1701 00 [00101000] - Locked
              Intermittent - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 37
                        Mileage: 168673 km
                        Date: 2024.10.09
                        Time: 09:59:55
                        Engine RPM: 852 /min
                        Transmission input speed: 852 /min
                        Transmission output speed: 0 /min
                        Engine torque: 0 Nm
                        ATF temperature: 46 °C
                        Accelerator pedal position: 0.0 %
                        Clutch status: Beide Kupplungen offen
    Address 03: ABS Brakes (J104)       Labels:. 4G0-907-379-V1.clb
       Part No SW: 4G0 907 379 L    HW: 4G0 907 379 L
       Component: ESP PREMIUM   H09 0450
       Revision: --------    Serial number: --------------
       Coding: 27A69F01E465F980FB00
       ASAM Dataset: EV_ESPPremiAU57X 004039
       ROD: EV_ESPPremiAU57X_004_AU57.rod
       VCID: 3A2E3B8E3CD34EFA517-806E
    4 Faults Found:
    0486 - Function Restriction due to Faults in Other Modules
              U1113 00 [00001000] - -
              [Ldm_ApbFailureState]
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 110
                        Mileage: 168075 km
                        Date: 2024.09.23
                        Time: 14:32:10
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        F-Path: 02
                        F-Type: 08
                        Uz: A6
    0604 - Tire Pressure Warning
              C102D 00 [00001001] - -
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 69
                        Reset counter: 95
                        Mileage: 168509 km
                        Date: 2024.10.04
                        Time: 14:40:23
                        VzRef: 36
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 26
                        Bit Info 4: 1F
                        F-Path: 01
                        F-Type: 2C
                        Uz: BB
    0629 - Tire Pressure Warning
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 68
                        Reset counter: 95
                        Mileage: 168514 km
                        Date: 2024.10.04
                        Time: 14:55:17
                        VzRef: 00
                        Bit Info 1: 80
                        Bit Info 2: 0F
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 01
                        F-Type: 30
                        Uz: 9D
    0692 - Function Restriction due to Faults in Other Modules
              [SCL_EPB_Spannkraft_Error]
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 109
                        Mileage: 168075 km
                        Date: 2024.09.23
                        Time: 14:32:10
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        F-Path: 02
                        F-Type: 06
                        Uz: A6
    Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
       Part No SW: 4H0 907 064 DN    HW: 4H0 907 064 DN
       Component: BCM2 2.0      H35 0510
       Revision: 00002001
       Coding: 01B93046000000000000
       VCID: 78AAE18642DF9CEA673-802C
       Subsystem 2 - Part No SW: 4H0 905 852 C    HW: 4H0 905 852 C
       Component: J764 ELV MLB  H40 0046
       Serial number: 0213000355983016
    No fault code found.
    Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
       Part No SW: 4G0 820 043 AK    HW: 4G0 820 043 AK
       Component: KLIMA 2 ZONEN H14 0094
       Serial number: 19111300111683
       Coding: 3622000821
       ASAM Dataset: EV_AirCondiBasisUDS 004002
       ROD: EV_AirCondiBasisUDS_004.rod
       VCID: 688AB1C612FF0C6AF73-803C
    Address 09: Cent. Elect. (J519)       Labels:. 4H0-907-063-V1.clb
       Part No SW: 4H0 907 063 CF    HW: 4H0 907 063 F
       Component: BCM1 2.0      H12 0130
       Revision: 20012002    Serial number: 00000001656539
       Coding: 2600201040349FE00181008300001D0C0F9DE70827090201000004606100
       VCID: 6E86C7DE309BD25ABDF-803A
       Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS57X 131026  H36 0080
       Serial number:         131028133554
       Coding: 0045F7
       Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
       Component: G397_RLFS  H06 0002
       Serial number: 21962499
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 S    HW: 4G0 941 531 S
       Component: E1 - LDS  H07 0044
       Serial number: 15 11 2013  00001329
       Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
       Component: Humidity_Sens  H03 0002
       Serial number: C028CBD6000000000001
    Address 10: Park/Steer Assist (J446)       Labels:| 4H0-919-475-7X2.clb
       Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
       Component: PARKHILFE ACC H01 0083
       Revision: 11001001    Serial number: 61061332700594
       Coding: 89C308
       ASAM Dataset: EV_EPHVA18AU57X0000 004009
       ROD: EV_EPHVA18AU57X0000_004.rod
       VCID: 71BCDCA22125CDA2A0D-8024
    Address 15: Airbags (J234)       Labels:* 4H0-959-655.clb
       Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
       Component: Airbag10.43   H43 0040
       Revision: --------    Serial number: 003JG00FRC9F Dataset Number: 4G0909602H  0002
       Coding: 3032343631334E303537554A305234473053
       ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
       ROD: EV_AirbaAU10BPAAU64X_VW51.rod
       VCID: 36362FBE08CBAA9AB5F-8062
       Crash sensor for side airbag: driver side:
       Serial number: 3575HRB400K50LNGGQ4
       Front Passenger's Side Airbag Crash Sensor:
       Serial number: 3585HRB406123HNCCOU
       Rear Side Airbag Crash Sensor (on driver's side):
       Serial number: 3515JRB400450OCCLOLQ
       Passenger side rear thorax airbag crash sensor:
       Serial number: 3525JRB400G50OCCKHEO
       Crash sensor for front airbag: driver side:
       Serial number: 3554VRB400Q50P7AAOI0
       Crash sensor for front airbag: front passenger side:
       Serial number: 3564VRB400G50P7AQA1J
    Address 16: Steering wheel (J527)       Labels:. 4H0-953-568.clb
       Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
       Component: Lenks.Modul   H05 0201
       Revision: 00000000    Serial number: 20131119000126
       Coding: 000035
       VCID: 303A19A6EA2F84AAEF3-8064
       Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
       Component: E221 - MFL  H08 0010
    Address 17: Instruments (J285)       Labels:| 4H0-920-xxx-17.clb-SRI1
       Part No SW: 4G8 920 984 H    HW: 4G8 920 984 H
       Component: TDieGb        H58 0621
       Revision: 29460233    Serial number: 658051113596018
       Coding: 33A610000B412600010000
       ASAM Dataset: EV_RBD4K 004048
       ROD: EV_RBD4K_AU57.rod
    Address 19: CAN Gateway (J533)       Labels:| 4H0-907-468.clb
       Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
       Component: J533--Gateway H13 0050
       Revision: --------    Serial number: 00000001177849 Dataset Number: 4G0909515H  0067
       Coding: 00CD077D00
       GVL: FDA1E800DE6560010000
       ASAM Dataset: EV_GatewPkoUDS 001019
       ROD: EV_GatewPkoUDS_001_AU57.rod
       VCID: 72BED3AE2423F6BA597-8026
       Battery Monitoring Control Module:
       Subsystem 1 - Part No SW: 8T0 915 181     HW: 8T0 915 181
       Component: J367-BDMHella  H03 8041
       Serial number: 6266341703
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663
       Component: J532_DCDCStab  H23 0021
       Serial number: 13091400000000000041
    Address 3B: Sensor Elect. (J849)       Labels: 4G0-907-637.clb
       Part No SW: 4G0 907 637 H    HW: 4G0 907 637 D
       Component: SARA 3D       H03 0056
       Revision: --------    Serial number: EJ1BPA7207AD4. Dataset Number: 4G0909573C  0006
       Shop #: WSC 00000 000 00000
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 333016AA1BB9BFB2921-8066
    Address 42: Door Elect, Driver (J386)       Labels:. 4H0-959-793.clb
       Part No SW: 4G8 959 793 J    HW: 4G8 959 793 G
       Component: TSG FA        H03 0507
       Coding: 011C16004001620002080002
       VCID: 47C8527A7FA12312DE9-8012
    Address 44: Steering Assist (J500)       Labels:| 4G0-909-144.clb
       Part No SW: 4G0 909 144 L    HW: 4G0 909 144 G
       Component: RCEPS         H39 0010
       Revision: 00001000    Serial number: 0004012430 Dataset Number: 4G0909852H  0027
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: 323E13AEE4A3B6BA997-8066
    Address 46: Central Conv. (J393)       Labels:. 4H0-907-064-46.clb
       Revision: 00002001    Serial number: 0320254501
       Coding: 013B0622A0B930008320090420010F470000000000000000000000000000
       Subsystem 1 - Part No: 4G0 951 177
       Component: DWA-Sensor  H01 0010
       Subsystem 2 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HO  H05 1501
    2 Faults Found:
    02615 - Fuel Tank Cap; Lock
                009 - Open or Short to Ground
                 Freeze Frame:
                        Fault Status: 01101001
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 235
                        Mileage: 163098 km
                        Time Indication: 0
                        Date: 2024.06.30
                        Time: 17:04:11
    02616 - Fuel Tank Cap; Unlock
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 235
                        Mileage: 163098 km
                        Time Indication: 0
                        Date: 2024.06.30
                        Time: 19:49:53
    Address 52: Door Elect, Pass. (J387)       Labels:. 4H0-959-792.clb
       Part No SW: 4G8 959 792 J    HW: 4G8 959 792 G
       Component: TSG BF        H03 0507
       VCID: 46D65F7E78AB3A1A25F-8012
    Address 53: Parking Brake (----)       Labels: 4H0-907-801.clb
       Part No SW: 4H0 907 801 G    HW: 4H0 907 801 A
       Component: EPB-4         H03 0014
       Revision: --------    Serial number: 00000000883417 Dataset Number: 4G0909522D  0007
       ASAM Dataset: EV_ParkiBrake 001028
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2C020DD6C687E04AD3B-8078
    1 Fault Found:
    71680 - Right Parking Brake Motor Voltage Supply
              C100E 12 [00001000] - Electrical Malfunction
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 109
                        Mileage: 168075 km
                        Date: 2024.09.23
                        Time: 14:32:10
                        Voltage terminal 30: 13.2 V
                        Internal Fault ID: 29
                        Network management state: normal
                        Function light in parking brake button: OFF
                        Red operating lamp: OFF
                        Red warning lamp: OFF
                        Green operating lamp: OFF
                        Yellow warning lamp: OFF
                        Terminal 15 status: On
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
                        ACC requested apply: not active
                        Auto Adjust: not active
                        General Inspection Function: not active
                        Internal Parking Brake state: static
                        Status of parking brake button: Not operated
                        Status ParkingBrake left: is opened
                        Status ParkingBrake right: Open
    Address 55: Headlight Range (J431)       Labels:| 8X0-907-357.clb
       Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
       Component: ....LWR12.... H02 0010
       Serial number: 131118-0004-033
       Coding: 1122A6101000A300
       ASAM Dataset: EV_HeadlRegulBasic 005001
       ROD: EV_HeadlRegulBasic.rod
       VCID: 2D0400D2FD9DE942C45-8078
    Address 56: Radio (R)       Labels:. 4F0-035-0xx-56.clb
       Part No SW: 4G0 035 061 N    HW: 4G0 035 061
       Component: Radio U DAB   H60 0139
       Revision: AB001007    Serial number: 109KX0D7801241
       Coding: 010103020100000001
       VCID: 280AF1C6D2FFCC6A373-807C
    Address 5F: Information Electr. (J794)       Labels:. 4E0-035-6xx-5F.clb
       Part No SW: 4G0 035 670 J    HW: 4G0 035 670 J
       Component: H-BNT-EU      H53 0798
       Revision: --------    Serial number: 190K$0D7561451
       Coding: 050101010003A1ED05808B3E00000003000001000000000000
       VCID: 2A0E0BCECCF3FE7A217-807E
       Subsystem 1 - Part No: 8R0 060 884 BK
       Component: EUR 2014  1703
       Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
       Component: DU8 C7 SV  H43 0021
       Serial number: AUZ8ZDDD0032E9D
       Subsystem 3 - Part No SW: 4G2 919 610 C    HW: 4G2 919 610 C
       Component: E380 BDT C7  H11 0204
       Serial number: 90349MKB0016E
       Subsystem 4 - Part No: 8R0 060 961 F
       Component: CD-Database  5571
    3 Faults Found:
    00384 - Optical Databus
                011 - Open Circuit - Intermittent
                 Freeze Frame:
                        Fault Status: 00101011
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 116
                        Mileage: 168223 km
                        Time Indication: 0
                        Date: 2024.09.28
                        Time: 12:31:34
                 Freeze Frame:
                        Voltage: 12.20 V
    02259 - Information Display and Control Head (Front) (J685)
                 Freeze Frame:
                        Fault Status: 00100100
                        Fault Priority: 5
                        Fault Frequency: 254
                        Reset counter: 135
                        Mileage: 163095 km
                        Time Indication: 0
                        Date: 2024.06.30
                        Time: 16:59:15
                 Freeze Frame:
                        Voltage: 12.80 V
    03367 - Supply Voltage for Display Module
                002 - Lower Limit Exceeded - Intermittent
                 Freeze Frame:
                        Fault Status: 00100010
                        Fault Priority: 7
                        Fault Frequency: 73
                        Reset counter: 132
                        Mileage: 163094 km
                        Time Indication: 0
                        Date: 2024.06.30
                        Time: 16:49:52
                 Freeze Frame:
                        Voltage: 12.40 V
    Address 62: Door, Rear Left (J388)       Labels:. 4H0-959-795.clb
       Part No SW: 4G8 959 795 J    HW: 4G8 959 795 G
       Component: TSG HL        H03 0507
       Coding: 010814004001620002080002
       VCID: 49CC544269B5D562C8D-801C
    Address 69: Trailer (J345)       Labels:. 4G8-907-383-V1.clb
       Part No SW: 4G8 907 383     HW: 4G8 907 383
       Component: Anhaenger     H12 0100
       Revision: 5G001001    Serial number: 00000428918291
       Coding: 0100000000000000
       Shop #: WSC 12345 123 12345
       VCID: 71BCDCA221A5CDA2A0D-8024
    Address 6D: Trunk Elect. (----)       Labels:| 7N0-959-107.clb
       Part No SW: 4G9 959 107 B    HW: 4G9 959 107 A
       Component: HDSG-Modul    H03 0143
       Revision: 14003001    Serial number: 313300260 Dataset Number: 4G0909541D  0027
       Coding: 097205C011
       ASAM Dataset: EV_HDSGAu572 001022
       ROD: EV_HDSGAu571_AU57.rod
       VCID: 353428B215CDA182BC5-8060
    Address 72: Door, Rear Right (J389)       Labels:. 4H0-959-795.clb
       Component: TSG HR        H03 0507
    End----(Elapsed Time: 02:09, VBatt start/end: 11.7V/11.7V. VIgn 11.8V)-----
    Last edited by Crasher; 12-10-2024 at 02:10 PM. Reason: I can’t see why this post won’t code wrap properly, bloody stupid adverts don’t help!
  2. Re: Transmission fault code. A6 C7 3.0 TDI S-Tronic
    134 Post(s)
    2009 Post(s)
    I tried to code wrap this as normal but it keeps adding its own code wrap before the VIN and I can’t get rid of it and every time I try I get an advert with a woman in a red dress and an annoying tab across the bottom which I have to delete each time, bloody irritating!
    I can’t explain why some units randomly go into locked mode for no reason but they do. The only way I know around it is using ODIS. Don’t worry though, they will make sure this sort of thing doesn’t happen with self driving cars as that would be… interesting..
  3. Re: Transmission fault code. A6 C7 3.0 TDI S-Tronic
    Mar 2014
    Aylesbury Bucks
    21 Post(s)
    Thanks for your reply! I know ODIS is used to unlock a locked unit, or match a replacement unit, but is there anything else that can be done to a unit that has a glitch where it locked once, then unlocked itself upon reboot? Eg disabling component protect?
  4. Re: Transmission fault code. A6 C7 3.0 TDI S-Tronic
    134 Post(s)
    2009 Post(s)
    I have had and seen ECU’s corrupt their coding and lock for no reason where even ODIS can’t get back in. A friend of mine had one of his techs leave the ignition on all night on a quite new customers BM and it corrupted every ECU on the car to the point the dealer could not recover them… he shut down not long after! I fitted a new component protected BCM to a late Passat and it bricked the ABS ECU, locking it in left hand drive. My ODIS dongle was away being repaired and I had to use another friend’s ODIS to unlock it. One of my techs fitted a new BCM to a T6, copying the coding from the old one and pasting into the new one; this made every ECU in the van except the engine recode randomly and I spent three hours on ODIS software and coding management getting everything back. A garage brought a Polo 6R in to me where they had used Launch to code in a new BCM (usual stupid washer motor output failure) and this locked the ABS pump in left hand drive and I could not get it back. It ended up with their TPS taking the car away to their local dealer who fitted a need ABS ECU. There are more too…
  1. ‘99 1.6sr.... Need transmission code/type
    By 11thStreetMag in forum Golf MK4 - 1999 - 2004
    Last Post: 28-09-2020, 10:09 PM
  2. Transmission fault code!help!
    By monkslayer in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-05-2015, 04:42 PM
  3. Check Engine Light code- Transmission Sensor A
    By Red A4 in forum Parts & Accessory Price Requests
    Last Post: 16-09-2014, 02:39 PM
  4. Please Help Audi A4 Avant 2004 diesel (Tiptronic) - Transmission problems! fault code P0706
    By youdamann in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-04-2011, 10:13 AM
  5. Please Help Auto transmission fault
    By yorky19640 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-02-2011, 07:59 PM
