Thread: Airbag fault - no codes...
  1. Airbag fault - no codes...
    Hi again, anyone have any suggestions for the above?
    I've tried replugging the yellow connectors to the seat airbags and the steering wheel one. Next I suppose it's a case of dropping the glovebox and replugging the passenger side airbag and the control unit. Should I try the door crash sensors? Any other connectors I can try?
  2. Re: Airbag fault - no codes...
    131 Post(s)
    1973 Post(s)
    If the light is on and you can make comms with the air bag controller, there must be codes, what are you using?
  3. Re: Airbag fault - no codes...
    Just a cheap wireless device with Car Scanner app...
  4. Re: Airbag fault - no codes...
    131 Post(s)
    1973 Post(s)
    Typical result, needs something such as VCDS.
  5. Re: Airbag fault - no codes...
    That sounds sensible. Thx
  1. Airbag fault codes. Please help!!!
    By simonson82 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-11-2019, 12:53 AM
  2. Airbag Fault codes
    By thetowen in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-11-2014, 09:11 PM
  3. Fault codes engine and airbag
    By willc1985 in forum VCDS - Help Requests
    Last Post: 08-08-2013, 12:18 AM
  4. Please Help Airbag Light but no fault codes
    By Chris47 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-02-2011, 06:27 PM
  5. Air bag fault codes: Which airbag do I need to look at?
    By toff in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-04-2008, 10:17 PM
