Thread: A1 top mount replace
  1. A1 top mount replace
    Jun 2012
    Surrey
    6 Post(s)
    Replacing top mounts on 2014 A1, can I do this with strut on car still?
  2. Re: A1 top mount replace
    134 Post(s)
    2009 Post(s)
    You could if you really like making your life difficult.
  3. Re: A1 top mount replace
    Jun 2012
    Surrey
    6 Post(s)
    just in case it helps anybody.....when the first lower strut bolt was obstinate I decided to try on the car. Using my older proper spring compressors which have double opposed threads the springs compress in place having supported the hub. The top nuts can be done from above then lower the hub on the jack enough to pop off the rubber and bearing and putting the nut back on. No drams, it worked fine. (one of the cheap new compressors which have a single thread will not work easily because the threaded rod will get in the way.
  1. Replace Strut Mount
    By warptechno in forum Passat CC
    Last Post: 22-05-2020, 12:34 AM
  2. Transmission mount: Is it time to replace? (video)
    By defever in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-05-2016, 04:05 PM
  3. Question Engine Cover Rubber Mount - how do I replace this?
    Last Post: 05-12-2014, 09:39 PM
  4. How To Replace the front engine mount at a 35i
    By Dr944S2 in forum Early Passat Forum - Pre 97
    Last Post: 21-11-2011, 10:46 PM
  5. How To Replace a rear gearbox mount...
    By blackcat in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-07-2011, 06:06 PM
