Thread: 2010 Polo Tdi subframe removal
  1. 2010 Polo Tdi subframe removal
    Aug 2021
    Newport
    I may have to drop the subframe on the above car, changing out an exhaust temperature sensor after the dpf has turned into a bit of a nightmare, the threads have galled up and access isnt great.
    Im awaiting an M14 x 1.5 tap and will hope that works but just want to get the sequence right if i need to drop the subframe to remove the dpf completely.
    Its the 3 cylinder diesel engine, im unsure on the capacity.
    Ive done a 2008 Mk5 Golf before so maybe its very similar?
    Thanks.
  2. Re: 2010 Polo Tdi subframe removal
    Aug 2021
    Newport
    All resolved now, no need to drop the subframe, was a pita tapping the threads out but not too bad a job. One of the sensors was a real bitch to get out and felt as if it was going to shear off so beware if your taking on this job.
  1. DPF( Front subframe) removal
    By den9112 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 30-10-2020, 01:24 PM
  2. 3.0 TDi Engine/Gearbox/Subframe order of removal + chains questions
    By zit501 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-03-2018, 01:51 PM
  3. popping sound after subframe removal
    By Shahzaib in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 24-01-2014, 12:16 AM
  4. Question 2010 polo exterior door handle removal?
    By elkieboy in forum Polo - Derby - Lupo - Fox
    Last Post: 08-04-2013, 08:53 PM
  5. 2010 polo exterior door handle removal?
    By elkieboy in forum Body Work, Body Styling and Body Kits
    Last Post: 08-04-2013, 07:58 PM
