Thread: low pressure fuel pump
Results 1 to 8 of 8
  1. low pressure fuel pump
    Mar 2009
    Crewe Cheshire
    8 Post(s)
    I have a golf gtd mk6 cfgb engine and I get p0087 low pressure since it was mapped but only if I drive it hard , changed the fuel filter and I am now going for the lpfp but gsf list two very different looking pumps , or is one the complete pump and sender and one just the pump that goes into the existing unit Screenshot (3).jpgScreenshot (3).jpg
  2. Re: low pressure fuel pump
    Feb 2020
    Bradford
    40 Post(s)
    The 2.0 also has an inline pump near the dpf pressure sensor area. The image does look like one of these secondary pumps.
  3. Re: low pressure fuel pump
    Mar 2009
    Crewe Cheshire
    8 Post(s)
    Why does it have a lift pump in the tank and then an extra inline one as well ?
  4. Re: low pressure fuel pump
    118 Post(s)
    1883 Post(s)
    What is the VIN? Some early Golf 6 2L TDI has an in tank lift pump, then another in line Bosch 044 style pump (actually 0 580 464 121) to bring the fuel deleievery to the mechnaical high pressure pump upto 4 Bar and later this was discontinued as it wasn't deemed necessary
  5. Re: low pressure fuel pump
    Mar 2009
    Crewe Cheshire
    8 Post(s)
    I am away at the moment so can't get the vin but it's a 2010 61 reg gtd cfgb engine , so some have two pumps ??? Is it likely this is my issue ? How can I prove it ?
  6. Re: low pressure fuel pump
    118 Post(s)
    1883 Post(s)
    Not easy to prove. I had a very early Golf 6 GTD in years ago that drove me to distraction with random fuel starvation, after trying everything I decided to start from scratch, I found that the first time it broke down it had a new in tank lift pump fitted and the garage put the fuel lines back on the sender top the wrong way around and due to the suction power of the additional electric pump it ran, without that pump it would never have run.
  7. Re: low pressure fuel pump
    Mar 2009
    Crewe Cheshire
    8 Post(s)
    Would vcds show anything to prove where the issue is ? Or am I just going to have to swap things
  8. Re: low pressure fuel pump
    118 Post(s)
    1883 Post(s)
    What is the VIN? VCDS measuring blocks in graph form and logging can help tie chnages in readings to the problem occuring. My initial reaction would be to return to the factory map and see if it still does it.
  1. Question 3.0TDI High Pressure Fuel Pump
    By graeme1808 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 05-03-2024, 06:13 PM
  2. Question Can a High Pressure Fuel Pump just fall off?
    By matapaca in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 03-07-2021, 01:10 PM
  3. 2.0 FSI High Pressure Fuel Pump Refurb
    By AudiYaDo? in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-06-2021, 11:25 AM
  4. Please Help GT TDI 170, hesitation, High pressure fuel pump failure/fuel contamination
    By Bruceakm in forum Golf MK5 - 2004 - 2009
    Last Post: 05-03-2014, 08:50 PM
  5. High pressure fuel pump replacement I THINK?
    By MathewRB in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-12-2008, 09:16 PM
