Thread: Timing belt tensioner failure
Results 1 to 10 of 11
  1. Timing belt tensioner failure
    Aug 2024
    Sandhurst berkshire england
    Back in May my timing belt tensioner stud failed after a cambelt change 6-8 weeks after. After that I investigated the damage into the cylinder head and found the rocker arms were all damaged and so have replaced them all and removed all the old broken parts. I also replaced the cam shafts with secondhand ones sourced from an engine centre. I refitted all the parts, so now the car starts and runs, the idle is ok however the car judders heavily like a heavy misfire, over 2500RPM. and smokes slightly I was told it could be due to the new camshafts. One of the lobes also looks slightly worn. Also Ive been told the camshafts can twist when theres a cambelt failure, therefore they should be replaced to new ones - is this correct? Also wondering if it couldve bent one of the cylinder head valves. Do you have any other ideas?
  2. Re: Timing belt tensioner failure
    131 Post(s)
    1973 Post(s)
    At what sort of speed did the stud fail and which code code?
  3. Re: Timing belt tensioner failure
    Aug 2024
    I was probably traveling 20 - 25 mph
    At moment there are no eml lights on
  4. Re: Timing belt tensioner failure
    131 Post(s)
    1973 Post(s)
    Which engine code or the VIN?
  5. Re: Timing belt tensioner failure
    Aug 2024
    2.0 tdi pd bkd engine
  6. Re: Timing belt tensioner failure
    131 Post(s)
    1973 Post(s)
    I would expect 2 to 4 broken rocker arms at least.
  7. Re: Timing belt tensioner failure
    Aug 2024
    In total there were only 2 unbroken rocker arms , however i replaced the whole set.
    I had to very carefully take out every broken piece, by also removing the sump & oil strainer.
    I painfully & time consumingly managed to collect all the pieces.
  8. Re: Timing belt tensioner failure
    Aug 2024
    Ive been told when there is cambelt failure you have to replace the camshafts as they twist, to avoid valve damage
    Is this true?
  9. Re: Timing belt tensioner failure
    131 Post(s)
    1973 Post(s)
    We have done quite a few and not had a problem. The worst one is the longitudinal installation such as an A4, you have to drop the engine right down to get the rocker tubes out.
  10. Re: Timing belt tensioner failure
    Aug 2024
    Yes definitley agree
    Whag woulc your opinion be about the camshafts?
    Would you say the camshafts need to be replaced after a cambelt failure?
    Do these engines usually damage valves when this occurs?
  1. Question 2001 Allroad 2.5tdi AKE timing belt tensioner failure
    By skyegtb in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-11-2014, 11:01 PM
  2. 1.9 tdi AWX timing belt tensioner
    By Crispy87 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-06-2013, 08:26 AM
  3. Please Help 1.8 20V Timing Belt Tensioner
    By exedriver in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-05-2010, 11:07 AM
  4. Timing Belt Tensioner Help!!
    By mrcheeezy in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 11-07-2008, 01:32 PM
  5. Please help! TDI Timing belt tensioner...
    By Kraig in forum Golf MK4 - 1999 - 2004
    Last Post: 04-03-2008, 06:25 PM
