Thread: Alternator Fault - Battery Not Charging. A6 C7.5
Results 1 to 10 of 18
  1. Alternator Fault - Battery Not Charging. A6 C7.5
    Mar 2024
    Lancashire
    Only had the car back a few weeks after it was off the road for months sorting adblue issues. I took the Audi Extended Warranty out after that to cover any other issues for the next year. Unfortunately I only did that on the -7th July and it doesn’t cover any issues for the first 30 days.
    Now today I hear a whining noise & a bit of a ‘pop’ and the message ‘Alternator Fault - Battery Not Charging’ comes up. Had to keep going & was luckily was only round the corner from home. But the rest of the drive, it intermittently sounded like the exhaust was dragging along the road under the car. I checked & there’s nothing hanging down.
    While the car was originally in at an Audi Indy for the adblue issue, they did report a Crankshaft synchronisation fault. I asked Audi several times about it but they assured me all faults were gone after changing the adblue line & tank.
    any likely causes or advice for approaching Audi with this?
    2016 Audi A6 C7.5 Avant, 3.0 BiTDI 320ps
  2. Re: Alternator Fault - Battery Not Charging. A6 C7.5
    Oct 2016
    Cambridge, UK
    14 Post(s)
    When that happened to me, Alternator Fault with Battery not charging, it was the alternator belt that had snapped, is your belt intact? It's something that can be sorted for well under £100.
  3. Re: Alternator Fault - Battery Not Charging. A6 C7.5
    Mar 2024
    Lancashire
    That gives me hope. I’ve seen the fault warning occurs on a range of models & I was worried it might be the crank pulley. Hopefully just a belt then & nothing worse, fingers crossed.
    did you have the same symptoms, with a nasty rattling/clattering sound like you were dragging the exhaust along?
  4. Re: Alternator Fault - Battery Not Charging. A6 C7.5
    Oct 2016
    Cambridge, UK
    14 Post(s)
    Mine is the 2.0 Ultra, and the alternator belt is visible if you open the bonnet, towards the front of the car. Don't know about the 3.0 BiTDI.
  5. Re: Alternator Fault - Battery Not Charging. A6 C7.5
    2009 Post(s)
    A crank/cams sync error on that engine is very concerning, however, the accessory drive belt can fail when the front lower pulley falls off! What is the VIN?
  6. Re: Alternator Fault - Battery Not Charging. A6 C7.5
    Mar 2024
    Lancashire
    The VIN is WAUZZZ4GXGN178291. The pulley falling off doesn’t sound very good either lol. At least to a non-mechanical person like me.
  7. Re: Alternator Fault - Battery Not Charging. A6 C7.5
    Jul 2023
    uk
    I've had an Audi with an alternator pulley that fell off but somehow it got wedged and didn’t disappear, turned out the one way clutch in the pulley had seized and the subsequent jerking eventually unscrewed the pulley from the alternator. A local garage fitted a new pulley and refitted the belt as it wasn't very old and in good nick.
    Now I think about it the last two cars I've had both needed new clutch pulleys at some point, one seized solid and the other would randomly sitck open so wouldnt drive the alternator. I wonder if good alternators get binned because of this?
  8. Re: Alternator Fault - Battery Not Charging. A6 C7.5
    2009 Post(s)
    Your car was built 12-04-16 and has the pulley where the bonding fails and the outer ring falls off, part 059 105 251 DA fitted up until 13-09-16 and was already a revised part for the original and since yours was built has been revised again at least three times to 059 105 251 EL which retails at £567.60. It is available aftermarket from Vaico under their number V10-6714
  1. Please Help 2002 Polo 1.4 TDi alternator charging fault
    By i-macca in forum Polo - Derby - Lupo - Fox
    Last Post: 08-06-2021, 07:17 AM
  2. Alternator fault- battery not charging
    By Sparky_143 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 25-02-2016, 09:37 PM
  3. Alternator Fault, Battery Not Being Charged!
    By P Smiddy in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 26-12-2013, 08:34 PM
  4. Question Audi S4 Alternator/Battery charging issues.
    By Evolutionuk in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-02-2013, 05:46 PM
  5. Can I use VCDS to check the alternator / battery charging OK ?
    By headache56 in forum VCDS - General Questions
    Last Post: 12-02-2012, 07:54 PM
