Thread: Upper rear wishbone
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: Upper rear wishbone
    #11
    Aug 2008
    So just getting all the bushes together to start this little project.....
    According to my tame Audi dealer ( they do exist!) the 2 'swinging bushes' on the axel guide are 4F0505145A and 4F0505145B which equate to FEBI 30974 and 30975 respectively....... however this doesn't equate to ADAB-001 and ADAB-002!
    Has Audi got this wrong? they look more like subframe mounting bushes than anything else.
    '86 WR Ur quattro Tornado Red
    '2006 3.2l V6 quattro Estate
    Retrofits so far: Sat Nav, DAB, Electric folding dimming mirrors with auto dimming interior mirror
    Front and rear parking sensors, Rear parking camera, TPMS, Electric lifting tailgate
  2. Re: Upper rear wishbone
    #12
    2005 Post(s)
    What is the VIN?
  3. Re: Upper rear wishbone
    #13
    Aug 2008
    Quote Originally Posted by crasher View Post
    what is the vin?
    wauzzz4f16n030942.
  4. Re: Upper rear wishbone
    #14
    2005 Post(s)
    4F0505145A and 4F0505145B are the subframe bushes, the lower spring plate “axle guide” inner bushes are not available from Audi, only as complete arms 4F0 595 311 M and 321 M at £796.80 per side, retail inc. I can’t check deeper until tomorrow as TEC DOC is playing up after an update!
  5. Re: Upper rear wishbone
    #15
    Aug 2008
    So the axle guide bushes arrived yesterday......
    Note to self and anyone else doing this..... make sure you order the correct number of ADAB-001 bushes....it requires 2x ADAB-001 bushes per axel guide!!!!
  6. Re: Upper rear wishbone
    #16
    Aug 2008
    So finally got around to doing this......
    Dropped the rear part of the exhaust, easier than I thought, removed the calipers, undid the shocks, removed ABS sensors and EPB cables.
    Undid the 6 cardon shaft bolts connecting to the rear diff.
    Made a cradle for the rear diff to sit in on the jack and carefully removed the subframe bolts.............. and slowly dropped the diff.
    QUESTION:
    how the HELL do you get the cardon shaft to part from the rear diff? - could not get this to part. I was expecting it to be the same as my Ur q - just 2 mating surfaces - but it seemed not to be like this.
    Anyway, didn't want to cause any damage and have the car off the road, there was enough clearance now to remove the upper transverse links and replace them both. I did want to get the diff out so i could check the mountings, but didn't want to run out of time.
    After putting everything back together I still have the knocking noise!!!! - The links were in a pretty bad way, N/S especially, the rubber had started to come away from the metal bush so it defo needed doing.
    Going to do the axle carriers next, should have my pneumatic press built by the weekend so should be a relatively straight forward job.
  7. Re: Upper rear wishbone
    #17
    2005 Post(s)
    Cardan shaft
  1. Golf mk5 wishbone and wishbone mount bolt sizes
    By daz2208 in forum Golf MK5 - 2004 - 2009
    Last Post: 13-01-2015, 11:32 PM
  2. polo rear wishbone bushes
    By redrocket in forum New Member Introductions
    Last Post: 08-05-2011, 10:17 PM
  3. rear upper suspension arm
    By ju1es1970 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-05-2010, 07:21 PM
  4. bushing in rear suspension/wishbone
    By stof in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-04-2010, 01:10 AM
  5. Polo wishbone rear bushes
    By sbhammo in forum Polo - Derby - Lupo - Fox
    Last Post: 07-04-2008, 09:17 PM
