Thread: Replacing EGR valve
Results 1 to 9 of 9
  1. Replacing EGR valve
    Dec 2015
    Belgrade
    Hi all,
    Last year I had issues with the EGR valve on my 2.0 TDI 110 HP Bluemotion 2014 Tiguan and after replacing new one everything seemed to be right but after less than one year and 6k miles I have had issues again with newly installed EGR. Couple times car was loosing power, start-stop error on the board and also check engine and finally after running VCDS there was P042E error saying that EGR stucked open. Couple days ago I have installed new EGR valve and via VCDS have done EGR adaption (Engine -> Basic settings -> Adaption of EGR vacuum regulator solenoid valve). Is there anything else that should be done via VCDS to be sure EGR is now running smoothly?
  2. Re: Replacing EGR valve
    131 Post(s)
    1973 Post(s)
    If you fitted a none genuine valve, you will be doing it again soon.
  3. Re: Replacing EGR valve
    Dec 2015
    Belgrade
    I have mounted Wahler (it has VW AG sign). It should be the genuine, looks and has the same lettering as the factory valve had. Previous EGR valve was BorgWarner with Wahler cooler.
    Here is how looks the new one installed:
    And this is the previous BorgWarner that looks like was running 200k miles:
    Because of that my question was should I do something else in VCDS beside EGR adaption in Basic settings which I've already done to check if everything is fine with EGR and running smoothly? I hope that the old valve was faulty from the beginning and there isn't anything else faulty that could lead to premature EGR failure.
  4. Re: Replacing EGR valve
    131 Post(s)
    1973 Post(s)
    There are EGR tests but f it is happy don't bother.
  5. Re: Replacing EGR valve
    Dec 2015
    Belgrade
    Sorry, didn't understand you there are EGR tests but?
  6. Re: Replacing EGR valve
    Mar 2010
    Derry ireland
    63 Post(s)
    Can you post up the engine code on your tiguan
  7. Re: Replacing EGR valve
    Dec 2015
    Belgrade
    Engine is CFFD, and ECU modul is 03L 906 018 LK
  8. Re: Replacing EGR valve
    131 Post(s)
    1973 Post(s)
    There are EGR tests in basic settings but if it is working, leave it.
  9. Re: Replacing EGR valve
    Dec 2015
    Belgrade
    Damn it, while browsing basic settings I've accidentally pressed "IDE00461 Resetting of learned values f closing time correction f inj 4". Does anybody know what this setting do and could this reset reflect on the fuel injection or particular injector?
  1. 1.9TDI jerking/no turbo after replacing EGR valve
    By VAGMAN2 in forum Golf MK5 - 2004 - 2009
    Last Post: 26-07-2011, 06:52 PM
  2. turbo not working..after replacing egr-valve
    By tonty42 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 02-03-2010, 11:25 AM
  3. Does my 2.5TDI EGR valve need replacing??
    By omniquito in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 13-08-2009, 05:51 PM
  4. Replacing valve guide seals
    By Odyssey in forum Early Passat Forum - Pre 97
    Last Post: 29-10-2008, 01:37 PM
  5. replacing atmospheric dump valve with re-circ dump valve
    By vwgolfturbo in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 04-02-2007, 10:27 PM
