Thread: No 4 EGT Sensor Question
  1. No 4 EGT Sensor Question
    Jun 2007
    I could post on my original thread so just to follow up on why the DPF would'nt regen after a clutch change which may be helpful to others:
    After many hours of work - removing and cleaning EGRV, replacing glow plus and checking sensors it turns out No 4 EGT sensor had been replaced by an incorrect sensor which was working in reverse to how it should (telling the ECU it was getting colder despite getting hotter). This meant despite the car trying to regen the ecu didn't register the DPF temperature as being sufficient to regen the DPF. Replaced the No 4 EGT sensor with the correct one and the car regenerated the DPF as normal once up to temperature.
    I know the incorrect sensor was fitted in the last 240 miles as that was the distance since the previous regen and the only people who have touched the car was the 'clutch specialist'. So what I think happened is they damaged the no 4 EGT sensor when moving the gearbox to change the clutch. They then replaced it with what they thought was the correct sensor (but wrong one for my car).
    I can't prove it was the clutch specialist but its the only rational explanation? I have called them twice but they are very vague and said they need to speak with the manager when he returns. I intend to follow up again today with them as its now confirmed it had the wrong sensor fitted. I'm more annoyed they didn't tell me what happened when I first asked as it could have saved me many hours of work and head scratching. I'll push them to pay £230 for a genuine Audi sensor - I think that seems fair?
  2. Re: No 4 EGT Sensor Question
    2005 Post(s)
    If they did break it and fit a new one then they should have told you. If it was damaged during removal to facilitate removing the gearbox then they should not only have told you but charged you for it as things like that happen and EGT sensors are notorious for galling their threads during removal, we try to never remove them unless faulty. The official line is to remove the front pipe and leave the DPF in place tied out of the way so they probaly removed it and instead of disconnecting the sensor and taking it out with the filter, removed it and the threads galled. Part number 03L 906 088 DR, £221.40 retail inc. If that is what happened, it's an awkward one.
    By mrcheeezy in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 02-08-2024, 02:08 PM
  2. question about MAF sensor
    By slackboy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-09-2010, 09:59 PM
  3. MAF sensor question
    By 5up3rman in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-05-2010, 05:04 PM
  4. MAF sensor question.
    By Enzed in forum Golf MK4 - 1999 - 2004
    Last Post: 24-05-2010, 11:34 PM
  5. MAF sensor Question
    By godfried in forum Archive posts
    Last Post: 22-08-2007, 07:21 AM
