Thread: Hesitation when accelerating from stationary on uphill
Results 1 to 10 of 13
  1. Hesitation when accelerating from stationary on uphill
    Jun 2011
    chester
    I have a 2012 Audi A6 C7 automatic multitronic sport diesel.
    When car is stationary on an uphill, and then when pulling away it judders and sometimes can cut out. You have to get the accelerator at a sweet spot to keep engine from cutting out. Too much gas or too little will make the car cut out or judder when pulling away.
    Its not a daily occurrence but happens now and again.
    EGR has been renewed not long ago. New fuel & air filter. Transmission Oil changes have been done accordingly. This issue has got gradually worse overtime.
    Could it be the oxygen sensor?
    Please help
  2. Re: Hesitation when accelerating from stationary on uphill
    Dec 2007
    Dudley, West Midlands
    44 Post(s)
    Could be a lot of things only option is a scan with an OBD tool such as VCDS
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  3. Re: Hesitation when accelerating from stationary on uphill
    Jun 2011
    chester
    So after scanning, there's no fault coming up. What should I look into in terms of the live results? Thanks
  4. Re: Hesitation when accelerating from stationary on uphill
    Dec 2007
    44 Post(s)
    Last time i had a car die as i tried to pull away it was fuel pressure sensor on the high pressure fuel pump, but that left a fault code
  5. Re: Hesitation when accelerating from stationary on uphill
    133 Post(s)
    1987 Post(s)
    When it acts up, does the rev counter drop to zero or drop more rapidly then you would expect, jumping up again when it recovers?
  6. Re: Hesitation when accelerating from stationary on uphill
    Jun 2011
    chester
    So the RPMs are low anyway because the engine is idle, and then when trying to pull away the RPMs drop but quickly recover after pulling away. That's if the engine of course hasn't decided to cut out.
    Could it be
    MAF
    Oxygen sensor
    Fuel not being pumped forward with enough pressure on an uphill? Maybe an inline fuel valve ? Hmm
    Frustrating. Trying to think outside the box
  7. Re: Hesitation when accelerating from stationary on uphill
    133 Post(s)
    1987 Post(s)
    The reading of the rev counter dropping and recovering BUT critically not in relation to how you hear the engine , says to me crankshaft speed sensor failure and this is notorious for not leaving a fault code.
  8. Re: Hesitation when accelerating from stationary on uphill
    Jun 2011
    chester
    So just to be clear,
    Revs drop, engine hesitates and either the revs and engine recover or everything cuts out.
    Do you think it's still the crankshaft sensor? If so any idea where it's located. Not much info on this online.
  9. Re: Hesitation when accelerating from stationary on uphill
    133 Post(s)
    1987 Post(s)
    Remind me tomorrow with the VIN, I am off sick.
  10. Re: Hesitation when accelerating from stationary on uphill
    Dec 2007
    44 Post(s)
    Nothing serious i hope Mate, some nasty viruses doing the rounds again.
  1. Replies: 0
    Last Post: 14-12-2013, 08:47 PM
  2. Slight hesitation when accelerating
    By jmm86 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-09-2011, 12:22 AM
  3. Question a3 hesitation when accelerating
    By kus in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 17-05-2011, 08:06 PM
  4. A4 3.0 QS hesitation when accelerating.
    By oldGTI nut in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-05-2008, 08:17 AM
  5. Bora hesitation when accelerating
    By scubaking in forum Bora - 1998 - 2005
    Last Post: 29-03-2007, 05:33 PM
