Thread: Vacuum causes turbo & brake servo problems
  1. Vacuum causes turbo & brake servo problems
    Oct 2006
    Hi all i drive an audi a6 1.9tdi avant 130pd with 125000 miles.
    I have owned it for 18 months and in that time have tried to solve this mystery. The turbo only kicks in when it feels like it, when it does the car runs really well responsive throttle,very good acceleration, and the brake pedal stops the car sooner on the stroke and is more powerful. I did have the vacuum pipes checked out via a audi garage, not main dealer, and they found nothing wrong. so have checked the egr valve had it blanked off no change so refitted it. changed the maf. changed fuel filter. had a remap...at first thought this cured it. Am now having audi main dealer take a look at the vacuum system since reading on Audi-sport.net where a guy was having similar symptoms. will keep you posted.
  2. Re: Vacuum causes turbo & brake servo problems
    Oct 2006
    hi all , Audi main dealer spent 1.5 hours checking vacuum system and charged me £109 for nothing found. They did find a split in my near side c.v. rubber boot which i am having done this monday coming. Cheers
  3. Re: Vacuum causes turbo & brake servo problems
    Oct 2006
    Problem solved at long last!
    I took my car to Elite vehicle repairs in Thornaby on Tees, Cleveland, Phil the owner, diagnosed a faulty tandem pump and replaced it. Total cost £395. Am well chuffed, the car goes like it should now. Phil's telephone number is mobile
    07817847416.
  4. Re: Vacuum causes turbo & brake servo problems
    Oct 2006
    what's the tandem pump & where is it located ?
  5. Re: Vacuum causes turbo & brake servo problems
    Oct 2006
    hi ss069,
    the tandem pump is one half the fuel injection pump the other half a vaccuum pump. is situated on top of engine somewhere not sure where.
  1. Polo/Lupo brake servo pipe.
    By westie383 in forum Polo - Derby - Lupo - Fox
    Last Post: 02-09-2008, 11:34 PM
  2. Brake servo, whisling
    By t4otte in forum New Member Introductions
    Last Post: 01-10-2007, 11:27 PM
  3. Brake servo & master cylinder removal
    By nezvos in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-09-2007, 09:24 AM
  4. A6 2.5 TDI brake problems
    By doggy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 11-06-2007, 09:09 PM
  5. Servo assistance fading........
    By Fourbears in forum Vento - 1994 - 1998
    Last Post: 29-04-2007, 09:37 PM
