Thread: 1.4 TFSI COD (CZEA) VCDS check for timing tolerance
  1. 1.4 TFSI COD (CZEA) VCDS check for timing tolerance
    Jan 2009
    Hello,
    I am a prospective buyer and will be viewing a car which has had a timing belt and waterpump replaced at non dealer garage. Having read this thread (thanks [Crasher] for linking to the tool) Warning light and VCDS cambelt error code following cam-timing belt change by local garage I understand 1.5 evo engine is quite particular about the camshaft timing being spot on and requiring the VAS 611 007 tool to achieve that. However, I was not aware the 1.4 TFSI could also require that tool to get the timing 100%.
    To check this with vcds would it be a case of checking specified vs actual degrees for camshaft measuring block values, and do you know what the specified tolerance is?
  2. Re: 1.4 TFSI COD (CZEA) VCDS check for timing tolerance
    134 Post(s)
    1995 Post(s)
    In theory the EA211 MAY require the 007 tool but in practice we have never had a problem. There is an automatic testing in basic settings I have used a few times but I don't recall it giving actual values, just yeh or nay sor such...
  3. Re: 1.4 TFSI COD (CZEA) VCDS check for timing tolerance
    Jan 2009
    Thank you Crasher, that's good to know
  1. Replies: 10
    Last Post: 18-07-2016, 11:27 AM
  2. 2.0l tfsi 177bhp timing
    By Anchco in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 16-03-2015, 06:32 PM
  3. Q7 tyre tolerance
    By Berti2005 in forum Wheels and Tyres
    Last Post: 18-06-2014, 10:32 PM
  4. check engine timing via vcds
    By Imran in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-03-2014, 09:53 PM
  5. Question TDI PD Timing check
    By PCDoctor in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-12-2011, 10:03 PM
