Thread: VW T5.1 2.0 Hot Start Issues and Erratic fuel pressure
  1. VW T5.1 2.0 Hot Start Issues and Erratic fuel pressure
    Apr 2024
    Hi
    I have a 2015 T5.1 CAAC with 102k miles.
    Owned about a year and always had the odd time is cranks for ages but it seems to have got worse.
    Symptoms are:
    Cold start fine
    Drive van even 2 miles, leave it 20+ mins and it then takes ages to start. Cranks fine but takes 10+ seconds to fire
    Hot immediate restart is fine, only happens if you leave it for a while
    VDCS shows
    Erratic fuel pressure even with engine off. Fluctuates from 60kpa to 400 ish.
    Cylinder 1 shows high injector reading, 2.6mg.
    Cylinders 2-4 show -1.2, -1.1, -0.3
    Changes fuel pressure sensor. No difference
    No error codes showing
    Drives ok, perhaps a bit sluggish but could just be overthinking it. Nothing obviously wrong when driving it.
    Garage wanted to remove HPFP to check for metal filings as a next step?
  2. Re: VW T5.1 2.0 Hot Start Issues and Erratic fuel pressure
    2014 Post(s)
    Check the fuel filter for sparkle dust, if present replace the HPFP and pray the dust didn’t get into the injectors.
  3. Re: VW T5.1 2.0 Hot Start Issues and Erratic fuel pressure
    Mar 2010
    Derry ireland
    67 Post(s)
    the fuel pressure control valve and the fuel metering solenoid and inter connected and has 2 different switched earths at ecu numbers b45 b60 needs to be checked out
  1. 1.6tdi Fuel Pressure Issues, Metering valve, regulator and pump seems fine
    By fransFourie in forum Jetta MK3 - 2005 - 2013
    Last Post: 01-11-2023, 06:54 PM
  2. erratic speedo / fuel gauge and low fuel beep on every corner
    By dannyboy201062 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-10-2012, 07:25 PM
  3. Replies: 0
    Last Post: 07-07-2010, 07:25 PM
  4. Erratic idle, misfiring, oil pressure light
    By madinnit1974 in forum Ibiza - Cordoba
    Last Post: 29-06-2010, 11:04 PM
  5. Which is the correct fuel? cold start issues
    By 80quattro1987 in forum 80 - 90
    Last Post: 26-04-2008, 06:22 PM
