Thread: Front Suspension knock 2012 A3 Tdi Quattro
  1. Front Suspension knock 2012 A3 Tdi Quattro
    Aug 2021
    Newport
    Just purchased this car from a work colleague, fairly well looked after, new bottom arms and drop links about a year ago.
    Has a suspension knock over bumps etc and just wondered what the common failures are.
    Had a quick look yesterday and can see no real play in Arb bushes, droplinks, console bushes etc, cant see any cracks in spring.
    Maybe top mounts worth looking at?
    I chased a problem like this on a 2008 Mk 5 Golf Gti and it turned out to be the steering rack which was a nightmare to diagnose really, not sure if these suffer from the same problems.
    Loathed to drop the subframe to do Arb bushes as i dont think its them.
    May drop the track rod ends out today and see if any play is noticeable in the rack.
  2. Re: Front Suspension knock 2012 A3 Tdi Quattro
    120 Post(s)
    1886 Post(s)
    Steering gears (racks) for this platform are a major problem, they have been on back order from VAG for months so we have been buying them from Bosch.
  3. Re: Front Suspension knock 2012 A3 Tdi Quattro
    Aug 2021
    Newport
    Thanks, just my luck if it is the rack, i fitted a recon unit to the Golf but am not sure i want to spend £300 on it yet so will leave it for now.
  4. Re: Front Suspension knock 2012 A3 Tdi Quattro
    120 Post(s)
    1886 Post(s)
    £300… a Bosch exchange is about £1200!
  5. Re: Front Suspension knock 2012 A3 Tdi Quattro
    Aug 2021
    Newport
    Thanks.
    A question you may be able to answer for me.
    I find the S Line suspension on it very harsh, we used to have a 2010 A3 Sportback 140 and that was nothing like this.
    I dont really want to get into changing springs and dampers tbh at the moment but are they harsh as standard?
    I may do the top mounts in the future but when you go in so to speak you think about what else you could replace at the same time.
  6. Re: Front Suspension knock 2012 A3 Tdi Quattro
    Jun 2021
    Surrey England
    I am not a mechanic, when I had a similar problems of not being able to find the problem of knocking/noise on my car after multiple mechanics looked at it, I was told go and get the car put up on a ramp and do the "shaker plate" test - think this is what the MOT guys do - could be wrong.
    Anyway did the "shaker plate" test and they then road-tested the car and found the problem thanks to the shaker plate test - sorry if you knew this already - would try this before spending big money on a steering rack.
  7. Re: Front Suspension knock 2012 A3 Tdi Quattro
    Aug 2021
    Newport
    Forgot to report back but decided to put a pair of febi topmounts on the front and it was cured, quite an easy job as the springs didnt need compressing on this particular model.
  1. Front suspension knock
    By peter goble in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-05-2022, 09:42 AM
  2. Front suspension knock
    Last Post: 25-07-2020, 01:02 PM
  3. Help. Knock from d/s front suspension
    By Jdot in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 02-02-2016, 04:39 PM
  4. Front suspension knock
    By Dave Avant in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-07-2009, 03:49 PM
  5. Front suspension knock....
    By randall977 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-02-2009, 11:12 AM
