Thread: VCDS - Bridport, Dorset
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. VCDS - Bridport, Dorset
    Aug 2007
    I'm in Bridport, Dorset. Have full VCDS Hex CAN. Let me know if I can help
    Andy
  2. Re: VCDS - Bridport, Dorset
    Mar 2015
    Bridport, Dorset
    Hi Andy,
    Are you still active here & have VCDS still?
    ~Dan
  3. Re: VCDS - Bridport, Dorset
    Aug 2007
    Hi Dan,
    yes im still here and I've got the VCDS
    cheers
  4. Re: VCDS - Bridport, Dorset
    Jul 2015
    Bridport
    Hi Andy - I have just moved to Bridport and own a SQ5 -I won't to add a sound booster (kufatec) but need 'drive select' which I don't have - are you able to enable it for me pls via vcds many thank Steve
  5. Re: VCDS - Bridport, Dorset
    Aug 2007
    Hi Steve - what year is your SQ5 - should be able to do it just need to check the instructions I have will cover your year
    cheers
    Andy
  6. Re: VCDS - Bridport, Dorset
    Jul 2015
    Bridport
    Hi Andy - it's 2015 only just picked it up cheers steve
  7. Re: VCDS - Bridport, Dorset
    Aug 2010
    Vristol, UK
    Do you still have VCDS and possibly available to recode a radio on a VW passat 2011?
    I have the instructions, its simply to enable the DAB digital reciever. I have the hardware just the software says no currently.
    Obviously I'd repay with bear tokens or something similar for your time.
    Regards,
    John
  8. Re: VCDS - Bridport, Dorset
    Aug 2007
    Quote Originally Posted by johnnypbristol View Post
    Regards,
    John
    Hi John,
    Yes I still have it and would be happy to help - I'll pm you my mobile number
    Cheers Andy
  9. Re: VCDS - Bridport, Dorset
    May 2017
    Cerne Abbas, UK
    Hi Andy,
    Are you still in Bridport ? I have recently started servicing my car myself after doing a course at Yeovil college. It's a 2009 A4 Allroad 2.0l TDI. I can reset the oil change counter but not the inspection service. Is that something you could do, I'm not an expert on the technical side of things.
    Thanks,
    Ollie
  10. Re: VCDS - Bridport, Dorset
    Aug 2007
    Hi Ollie,
    Sorry for the delay in replying, I have a new email so i've only just seen this. Yes I'm still in Bridport if I can help at all
    cheers
  1. Hi Dorset noob here
    By BiTdiSi in forum New Member Introductions
    Last Post: 28-08-2014, 10:31 PM
  2. Dubbing in Dorset
    By Olly1972 in forum Shows & Events
    Last Post: 25-05-2013, 08:41 PM
  3. Greetings from Dorset..........
    By stigish in forum New Member Introductions
    Last Post: 06-07-2011, 08:38 PM
  4. vcds or 5054 scan Hants or DORSET
    By bk.bas99 in forum VCDS - Users Locations
    Last Post: 05-01-2011, 08:41 PM
  5. vag-com in Dorset
    By deviseruk in forum VCDS - General Questions
    Last Post: 27-03-2008, 09:11 PM
