Thread: Time for a DPF Clean?
  1. Time for a DPF Clean?
    Jun 2007
    2014 Audi A7 3.0 TDI 205k miles
    All seems fine with the DPF regen’ing itself every 300 motorway miles and normal DPF pressure readings. I did a routine VAGCOM diagnostic with service and it says fault 5585 DPF blocked. I noticed the oil ash volume was 0.39L which I think is above the threshold hence the fault code?
    My question is - do I need to remove the DPF to clean it or can I do an ‘on the car’ clean adding cleaner via the temp sensor port? Do any of the of the shelf cleaners work or do I need to take it to a specialist DPF cleaner?
    many thanks for any advice.
  2. Re: Time for a DPF Clean?
    Jun 2007
    Here’s a pic of the fault code:
    Attachment 39440
  3. Re: Time for a DPF Clean?
    Jul 2008
    Lisburn
    16 Post(s)
    I would like to know also
    Your different pressure is at 8hPa, i hear this should be <5 at tick over and less than 50 at 3kRPM? to be confirmed.
    I believe, but again don't know for sure - the cleaners will sort the soot out but not the ash?
    Stewart
    1986 coupe quattro (kv)
  4. Re: Time for a DPF Clean?
    Jun 2007
    Yeh mine is normally 5 at tickover and about 35 at 3000 rpm. It hits about 200 at full power in sport mode which I try to avoid. I’ve noticed it varies with the engine loading (going uphill or accelerating) as the fuel flow increases which I guess makes sense.
    What is strange is when it regens the soot never drops to zero but stops at about 4g (not sure how it calculates it) - I was wondering if this represented the oil ash / soot it can’t burn off as I assume it can’t actually measure it but just calculates an estimate based on useage?
  5. Re: Time for a DPF Clean?
    Jun 2007
    So finally got round to removing the DPF and getting it professionally cleaned. Removing it was ok apart from the one exhaust nut that has to be accessed from below - this bit was a 2 man job really as one to hold the socket onto the nut on the lower DPF flange and one underneath the car to undo the nut. I had to use 2 long extensions and a universal joint but it worked - definitely not a nut to round off as can't see how you could recover as no access.
    The results from the DPF clean was:
    Before:
    Flow rate: 222 m3/h
    Back pressure: 34 m/bar
    After
    Flow rate: 415 m3/h
    Back pressure: 6 m/bar
    The DPF had done 200K so the before results were not surprising and a Lot of ash was removed (lots of motorway miles and shows good regens apparently).
    Anyway refit it today so it will be interesting to see what vagcom says.
  6. Re: Time for a DPF Clean?
    135 Post(s)
    2026 Post(s)
    Do a service regen when it is back on.
  7. Re: Time for a DPF Clean?
    Jun 2007
    So all seems good. Did a DPF reset after refitting DPF to clear the computed Ash value. After this it said it needed a regen so took it for a drive and regen'd fine. Thanks for the tip on service regen Crasher , it reduced the remaining measured soot value to zero and calculated soot to 4g (assume this is normal - not sure why the difference between calculated and measured?). Temps got high (620 deg c and some very hot smells from the exhaust - thought I was going to melt the tarmac!!). Anyway DPF pressure now reads 2 to 3 hPa on idle. Long motorway drive tomorrow, so will be interesting if MPG etc improves.
    I'm also pleased I managed to retrieve with a magnet the 12mm socket that dropped into the v when removing the DPF!!
  1. Question Carbon Clean / DPF Clean
    By Suri66 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 19-10-2020, 06:35 AM
  2. 3rd brake light not working , no revs , engine mangement on from time to time
    By icemano3 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 09-10-2013, 10:01 PM
  3. Get Your Pipes Sparkling Clean With Green Glass Clean!
    By usersight in forum General Detailing/Cleaning Questions
    Last Post: 16-11-2009, 12:12 PM
  4. Question MK4 Golf - Complete lack of grip from time to time
    By nburgess in forum Golf MK4 - 1999 - 2004
    Last Post: 31-05-2009, 08:09 PM
  5. How to clean and keep clean Light Beige Phoenix Cloth interior
    By ackerman821 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-01-2008, 04:36 PM
