We've had this car since 2017 and for the last 18-24 months have had a rattle that's getting slowly worse.
Rattles briefly after passing over a bit of rough road or undulation in the surface, possibly slightly more prevalent if accelerating lightly? Very noticeable at low speeds but maybe because road noise is less. Sounds to me like a worn damper bush or maybe anti-roll bar link or bush. I have had a good look at the suspension with wheels off and trays removed but a bit limited what I can do on the driveway with basic lifting tools. Also from the drivers seat it sounds like it is coming from front passenger side of car.
At the last MOT I explained all this to my friendly MOT tester so he had a real good look at the suspension and did find a broken rear spring , everything else checked out ok. I/we thought this must be it but after replacing the spring it is still there and still getting slowly slowly worse.
Really want this fixed in case it's something serious, and also have a family tour of Scotland coming up in a couple of months and really don't want to do a full weeks driving with the rattle bugging me....
Before I send it to a VAG specialist with a blank cheque option of 'FIX IT!' does anyone have any idea what it might be, anything common on this model that fails and rattles this way without being obvious?
