Thread: Touran 2.0TDI BMN cranks, no start
Page 4 of 4 FirstFirst ... 234
Results 31 to 35 of 35
  1. Re: Touran 2.0TDI BMN cranks, no start
    #31
    Apr 2024
    Hammerfest, Norway
    I had the fuel filter out, the top of the filter was almost dry. syphoned the canister of diesel, were almost empty. Activated the fuel pump thru VCDS and the lift pump makes the humming noise, but little to non fuel came to the canister after the 30 sec
  2. Re: Touran 2.0TDI BMN cranks, no start
    #32
    134 Post(s)
    2007 Post(s)
    New pump then.
  3. Re: Touran 2.0TDI BMN cranks, no start
    #33
    Apr 2024
    Hammerfest, Norway
    new pump bought.
  4. Re: Touran 2.0TDI BMN cranks, no start
    #34
    134 Post(s)
    2007 Post(s)
    Good luck.
  5. Re: Touran 2.0TDI BMN cranks, no start
    #35
    Apr 2024
    Hammerfest, Norway
    A long overdue update, after removing the fuelpump I noticed that the diesel was dark and full of ash-looking stuff floating around. Pumped out the dirty diesel and thoroughly cleaned the tank. Filled fresh diesel and mounted the new pump, the starting issue did not improve. Took out ASV and EGR yet again looking for soot and gunk, then I saw that the piston in the EGR valve was loose and I could turn it and there was 1 - 1,5 mm of opening from the valvehead to the valve seat. The valve itself did not move at all. Went ahead and made a planking plate for the EGR, mounted it and tried to start the car, it started intantly and the rough idle that had been a PITA before is gone. Car never felt more smooth and responsive. Here in Norway the law for emissions arent that strict, I will remove the EGR system completly and remap it.
  1. Question 1.9tdi 2004 Touran Cranks No start, no glow light, immob light on briefly
    By DaleC in forum Touran - Sharan - Caravelle
    Last Post: 10-02-2021, 01:22 PM
  2. Car Cranks wont start
    By hezim in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-05-2020, 10:07 AM
  3. O7 2.0 tdi A4 cabriolet cranks but won't start!
    By maggotrunner in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 16-06-2017, 08:42 PM
  4. Question Audi A6 2.7T cranks but won't start
    By eejit in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 24-08-2015, 11:06 PM
  5. Cranks but won't start
    By thevagcr in forum Golf MK4 - 1999 - 2004
    Last Post: 30-07-2012, 03:24 AM
