Thread: Audi Q3 2015 - P0299 00 [01100101] - Control Range Not Reached
Hybrid View
  1. Audi Q3 2015 - P0299 00 [01100101] - Control Range Not Reached
    Aug 2020
    Lancaster
    Hello,
    My father has just got an Audi Q3 2.0 TDI and it's started throwing up a fault. It appears to kick in mostly when he's accelerating up a hill and then let's off the accelerator.
    I've had a mityvac on the vacuum system, the pump is pulling between 25 and 30. When I apply vacuum to the n75 valve and actuator, I can pull between 25 and 30 and it stays without dropping.
    A N75 valve has been tested on it from a known working car.
    Car is on 57k.
    Dpf is at 13g.
    Any ideas what to check next?
    Address 01: Engine (J623-CUVC) Labels:. 04L-907-309-V1.clb
    Part No SW: 04L 906 016 BF HW: 04L 907 309 K
    Component: R4 2.0l TDI H20 2911
    Revision: 8AH20--- CVN: 5631847E92F1EF3C
    Coding: 02190012043701082000
    Shop #: WSC 34700 001 1048576
    ASAM Dataset: EV_ECM20TDI01104L906016BF 004002
    ROD: EV_ECM20TDI01104L906016BF_004.rod
    VCID: 6E85C2DC6019736ACDF-803A
    VINID: 9D196AAAA22525688010700124C9C664E9
    2 Faults Found:
    19225 - Boost Pressure Regulation
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 91239 km
    Date: 2024.04.11
    Time: 10:21:30
    Engine RPM: 2116.00 /min
    Normed load value: 100.0 %
    Vehicle speed: 51 km/h
    Coolant temperature: 79 C
    Intake air temperature: 33 C
    Ambient air pressure: 1000 mbar
    Voltage terminal 30: 14.840 V
    Unlearning counter according OBD: 40
    Charge air pressure: specified value: 2275 hPa
    Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 966.4 hPa
    Mass airflow sensor 1 bank 1 airflow: raw value: 426.6 mg/stroke
    Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 0.28 %
    Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 0.00 %
    Turbine actuator 1 bank 1: posit.feedback - Actual value: 93.74 %
    Mean injection quantity: 27.98 mg/stroke
    25710 - Boost Pressure Regulation
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 91239 km
    Date: 2024.04.11
    Time: 10:21:30
    Engine RPM: 2117.50 /min
    Normed load value: 99.6 %
    Voltage terminal 30: 14.860 V
    Mass airflow sensor 1 bank 1 airflow: raw value: 425.0 mg/stroke
    Mean injection quantity: 28.64 mg/stroke
    Readiness: 0 0 0 0 1
  2. Re: Audi Q3 2015 - P0299 00 [01100101] - Control Range Not Reached
    135 Post(s)
    2026 Post(s)
    If it is definitely not a blocked DPF then underboost is usually a leak in the vacuum control system. Have you put the mityvac on the mani source 3mm hose to the servo vacuum pipe? Is it an AdBlue car?
  1. Please Help Boost pressure regulation Control not reached P0299
    By Aaron1875 in forum Alhambra
    Last Post: 08-09-2022, 09:02 AM
  2. P0299 - 006 - Control Range Not Reached - Intermittent B6 Passat
    By silversimpson in forum VCDS - Help Requests
    Last Post: 25-07-2019, 08:37 AM
  3. 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached
    By s1paulj in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-08-2017, 08:33 PM
  4. Replies: 0
    Last Post: 27-05-2015, 04:21 PM
  5. P0299 Control Range Not Reached - Intermittent - MIL ON( Turbo fault)
    By Benoticed in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 27-07-2013, 04:37 PM
