Thread: Passat wings.
  1. Passat wings.
    Leicestershire
    8 Post(s)
    Afternoon all.
    I’ve had my Passat (2.0 TDI Sport BMR Estate) for two years now. When I bought it the front wings, as well of the rest of the car, were in pretty good shape for a 2006 vintage. Two years on, the drivers wing has a couple of small rust bubbles, right in the centre, 12 o clock if the wheel was a clock face. The passenger wing is worse, it has a patch about 100mm square at the bottom rear, where the wing meets the bottom of the passenger door. I’d like a few more years out of the car if possible but i don’t like the idea of driving around with scabby wings. I’m not at that point yet but does anyone have a rough idea how much it would cost to get two wings painted and fitted?
    Thank you 🙏🏼
  2. Re: Passat wings.
    111 Post(s)
    1858 Post(s)
    The wings on our 2010 loan car are really bad, must get them done. The prices will vary tremendously depending on the parts used, genuine at £274.20 or as little as £55 pattern but cheap aftermarket can take a LOT of work to make look right and won’t last as cheap ones are not zinc coated. Then there is painting which could be £50 a wing for a quickie or £250 a wing for a perfect finish AND pained inside as well as waxed internally. Then there is labour, it is fiddly work with potential finish damage if rushed. So I would say as little as £200 DIY except the painting to £1500 ish at a professional body shop using genuine wings, top quality work done to last.
    https://youtu.be/w8r2xnITnqA?si=Hy9T6jEbWD5ih-Oy
  3. Re: Passat wings.
    Apr 2024
    glasgow uk
    About £300
  4. Re: Passat wings.
    Jul 2023
    Carlisle, UK
    I've got a scrape and a bulge on my rear bumper - was quoted last year £360+ vat to fix and spray bumper
    Last A4 had scabby wings and I was quoted £650ish for supply and paint two none genuine wings about 5 years ago, I'm guessing that would be £800 or more now?
  5. Re: Passat wings.
    111 Post(s)
    1858 Post(s)
    £300 done for you will get a very low quality job that won’t last. You also have to factor in the possibility of needing to blend in the front doors, bonnet and bumper. A few weeks ago I had my minor damaged rear bumper painted and that was £200 trade.
    @gareth23 yes it would be about that with cheap aftermarket wings but £200 ish more for quality zinc plated. Did an insurance wing on a very early 8E a few months back, genuine is now obsolete and with quality aftermarket it was £600.
  6. Re: Passat wings.
    Jan 2013
    Wessex. and Southern France
    Depends how long you intend to keep it and just how good you want it to look. Pay cheap and that's what you get, a cheap job. If, if it was me and I wanted to keep the car for the foreseeable, I'd raid the piggy bank.
  7. Re: Passat wings.
    Leicestershire
    8 Post(s)
    Thanks for the replies guys.. good advice as always 👍🏽
    I’d like to think I could keep the car for another 4 or 5 years, and knowing how I am I don’t like a rubbish / cheap job.
  1. Anyone know if front wings are same on 3dr & 5dr?
    By sp1xel in forum Polo - Derby - Lupo - Fox
    Last Post: 09-03-2016, 07:02 PM
  2. mk 4 wings
    By pokernut69 in forum Body Work, Body Styling and Body Kits
    Last Post: 15-04-2015, 11:14 AM
  3. Wings
    By RichardSEL in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-08-2014, 08:55 PM
  4. Question front wings for a 2002 passat
    By chrismac10 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-04-2010, 07:28 PM
