Thread: Audi A3 2.0TDI CRLB 150bhp s-tronic
Results 1 to 8 of 8
  1. Audi A3 2.0TDI CRLB 150bhp s-tronic
    Nov 2013
    mandfield woodhouse
    Hi all just purchased a 64 plate Audi with 33k miles it's had a timing belt kit and water pump with aux belt fitted. Are these reliable engines / transmissions? Regarded as decent? any precaution maintenance I should look at for? Any thing I have sort of picked up on is a noise when facing the engine left hand side near timing belt area they is a chirping noise shall we say? But every car I looked at even the golf 184bhp cuna engine sounded the same...
  2. Re: Audi A3 2.0TDI CRLB 150bhp s-tronic
    134 Post(s)
    2013 Post(s)
    The engine itself is good if given 9300 mile oil chnages, the problems are the exhaust aftertreatment and the injectors.
  3. Re: Audi A3 2.0TDI CRLB 150bhp s-tronic
    Nov 2013
    mandfield woodhouse
    Good to know I'll drop a cleaner in the tank forte every now and then. I'll look at getting the s-tronic serviced soon
  4. Re: Audi A3 2.0TDI CRLB 150bhp s-tronic
    134 Post(s)
    2013 Post(s)
    Just run it on V Power
  5. Re: Audi A3 2.0TDI CRLB 150bhp s-tronic
    Nov 2013
    mandfield woodhouse
    Noted thanks. Why do the engines on these newer vw/Audi sound god awful ? I know it's normal what I hear on mine but they sound far from smooth?
  6. Re: Audi A3 2.0TDI CRLB 150bhp s-tronic
    134 Post(s)
    2013 Post(s)
    The EA289 pre May 2015 build engines sound like a skeleton ******* in a biscuit tin because of the camshaft module, later ones with the revised unit are much quieter.
  7. Re: Audi A3 2.0TDI CRLB 150bhp s-tronic
    Nov 2013
    mandfield woodhouse
    I have been to see alot of golf gtds before I settled on the Audi they was sort of 66 plates with 60-80k miles on 180bhp and they sounded just like the 150bhp Audi A3 64 plate some sounded worse than others but overall I would say they all sound like a bad pulley. I'm in two minds really to send the Audi A3 back they sound terrible these 2.0tdis
  8. Re: Audi A3 2.0TDI CRLB 150bhp s-tronic
    Nov 2013
    mandfield woodhouse
    So had the car nearly 2 months spent quite a bit on her full service also had the s-tronic serviced with oe oil and filter took that to a specialist had 4 new tyres and tracking and also front and rear discs and pads.
    Noticed a couple of things really from the gearbox when changing gear from 2 to 3rd might even do it in other gears I'll pay more attention to it tomorrow I hear like a clicking engagement noise?? Was there before service also I notice a whine mainly in 1st gear even more so when changed to manual from 1st to 2nd this normal?
  1. Question Audi A6 2.0tdi C7 2018 S tronic gearbox, 64k miles
    By ihsanu4 in forum New Member Introductions
    Last Post: 28-02-2024, 11:16 PM
  2. Question Ea288 2.0tdi crlb dpf system non adblue
    By N871BUD in forum 2.0TDi - Engine
    Last Post: 15-12-2023, 05:22 PM
  3. Audi A6 2.0TDI S-tronic (190PS) turbine problem
    By ekasteli in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 30-07-2018, 09:00 AM
  4. Please Help Audi A4 3.0Tdi v6 s-tronic auto quattro jul-2012 - idling at only 590rpm
    By david_walls in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 10-09-2016, 10:25 AM
  5. Audi A4 (B8) 2.0TDI 7spd S-Tronic BAD PULL AWAY
    By trj88888 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 24-04-2015, 09:14 AM
