Thread: Brake light switch - P0571 - limp mode - changed still a problem
  1. Brake light switch - P0571 - limp mode - changed still a problem
    Jun 2021
    Surrey England
    Searched forums can't find this situation -
    Audi A3 2004 2.0 TDI . Glow plug warning light came up, with brake pedal not on all brakes lit up
    Scanned with carista error code p0571. Cleared fault code and glow plug light returned.
    Went to euro car parts swapped over part simply unclicking and clicking that into place, did not touch pedal.
    Car now appears to be in limp mode, with new switch and old switch fitted brake lights on constant with ignition switched off !!! - battery drain.
    Remove brake light switch turn ignition off and lights remain off.
    Brakes seem normal when driving just limp mode and need to fix switch.
    Is limp mode because of faulty switch ?
    Help please !!
  2. Re: Brake light switch - P0571 - limp mode - changed still a problem
    134 Post(s)
    2005 Post(s)
    Sounds like a bad switch, even genuine ones can fail immediately and you are doing it the correct way.
  3. Re: Brake light switch - P0571 - limp mode - changed still a problem
    Jun 2021
    Surrey England
    Hi crasher, many thanks for this reply. Car is at garage at the moment and they are manic. You have given me confidence it could be just still the switch. I will attempt to get a genuine Audi one tomorrow instead of euro car parts, and see if I can get to the car over the weekend /update garage as your the expert/guru.
    Many thanks again will update asap.
  4. Re: Brake light switch - P0571 - limp mode - changed still a problem
    Jun 2021
    Surrey England
    Hi, just an update to anyone else who has this nightmare problem. It was eventually clutch pedal switch on master cylinder on bulk head in engine bay. It was also repeatedly blowing a fuse. I think 5amp no.7
  1. Replies: 2
    Last Post: 18-08-2017, 10:17 PM
  2. Question Brake Switch Fault P0571/16955
    By vfrvulcan in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-05-2011, 09:17 PM
  3. Brake light changed diesel coil light and brake light still on
    By Manny.p in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-09-2010, 02:04 PM
  4. 16955 Brake Switch (F): Implausible Signal : P0571
    By VWunited in forum Golf MK4 - 1999 - 2004
    Last Post: 18-02-2010, 02:11 PM
  5. Question P0571 brake light switch epc
    By tiredeyes69 in forum Golf MK4 - 1999 - 2004
    Last Post: 11-10-2009, 01:19 AM
