Thread: Gasket advice 3.0 TDI "V" Rebuild after EGR, Oil Cooler and Coolant Valve replacement
Threaded View
  1. Gasket advice 3.0 TDI "V" Rebuild after EGR, Oil Cooler and Coolant Valve replacement
    2014 A7 3.0 TDI CLAB Engine.
    Just rebuilding the components in the "V" after a coolant and oil leak. Replacing all gaskets, coolant valve and flange.
    I have a question for the rubber gaskets during the rebuild for the following below - should I leave them dry, lubricate with coolant or oil as appropriate or use something different - red rubber grease or silicon grease etc. My manual doesn't say anything which indicate leave dry but I have always used a wipe of oil on oil gaskets and coolant or red grease on coolant gaskets.
    Oil cooler plate to engine block gasket (oil and coolant gaskets)
    Oil cooler gasket (Oil and coolant gaskets)
    Coolant valve gasket to block
    Coolant flange to block
    O ring from flange to Oil cooler
    Intake Manifold to head gaskets
    Just want to get this right as don't want to revisit this!
    Thanks for any advice assistance.
  1. Replies: 35
    Last Post: 22-01-2015, 11:12 PM
  2. Please Help Any Other ideas? Oil in coolant after new oil cooler and head gasket
    By Mikeybs in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-04-2013, 10:44 AM
  3. A "Community" a "Club" or a "Technical Forum"?
    By stuart in forum Chat - Completely Off Topic
    Last Post: 07-03-2009, 02:11 AM
  4. Hi advice please for "newbe" Golf V6 4Mo wishbone replacement
    By lee1903 in forum New Member Introductions
    Last Post: 06-02-2009, 06:03 PM
  5. Cleaned EGR valve now car is "jumpy" in throttle response
    By conor2949 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-01-2009, 09:42 PM
