Thread: MK7 2.0 TDI GT (184), Oil leak from top of engine
Results 1 to 9 of 9
  1. MK7 2.0 TDI GT (184), Oil leak from top of engine
    Mar 2010
    Wakefield
    I'm helping out with my daughters 2.0 tdi GT 184 (around 65k on clock). She has owned the car about 18 months and put around 10k of these miles on herself, and is a very careful driver (99% of driving is done below 3500/4000 rpm!). Hence not a recent purchase, just a recent issue noted after 10k easy miles without any issues
    About 2 months ago she has a persistent an notable oil leak, which seems to be coming from the top of the engine. Thought is that it was losing perhaps 0.5 to 1ltr per week, with light usage. No issues with exhaust gases, neither blue nor white...just normal. But there is a repeat welling of oil around the glow plug recess, and then a downward migration of oil eventually to ground and fresh markings on driveways after parking.
    It was originally thought that the oil was leaking from above and possibly coming from the rocker cover gasket, so this was swapped out for the first time perhaps 4 weeks ago. After the 20 to 25 mile drive home, the problem remained.
    A second garage has done the rocker cover work again, all with genuine VW parts and the problem remains. Now about 100 miles since the second work and the problem remains.
    Yesterday, I got it on my ramps, took of the skid tray underneath and cleaned as much of the engine and subframe as I could. Whilst under the bonnet, I cleaned up around the glow plug area and also found that the oil level was too high, so I syringed about 300 to 400ml. Bringing the level down to the 'top' of the dip-stick checker. After a 10 mile drive, the oil leak is very visible on around the glow plugs again and a simple 3 point turn in the street left oil drip marks again.
    Professionally I work on cars from the 1920's through to 1980's, and carried out a few simple tests to then better understand....how, why and where the cause may be. Whilst bringing the basic tests into a much more modern vehicle.
    1) Oil filler cap off with engine running, there is a mild pulse of smoke/pressure coming out. Likewise at the dipstick tube.
    2) The highest point of wet oil, is just around the glow plug recess and the cylinder head below the rocker cover.
    3) No splash marks on the underside of the bonnet, hence it's not reaching the top of the engine by 'throw'. Instead it's being pressured 'to' and then leaking downwards.
    4) The oil level may have been too high previously, but it is now correct.
    5) Minimal, perhaps near zero leakage at idle. Hence, the leakage is only present with rpm and engine load.
    If on an older car, my thoughts would be turning towards an issue with 'blow by' or crank case breathers and under load the engine is struggling to breath/vent properly. The result being that oil is being forced out from somewhere...perhaps the rocker cover gasket, filler cap or a pcv pipe of some type at the top end of the engine.
    Does the problem sound familiar? Is there a PCV valve or breather which are known to fail, clog up, or other? Is this a common issue with a recognised 'typical' cause?
    Any help or advice offered would be very much appreciated?
  2. Re: MK7 2.0 TDI GT (184), Oil leak from top of engine
    Mar 2010
    Wakefield
    Another clean up under the engine bay this morning and I can now see an area where fresh oil is leaking outwards. It may not be the only source however, it is at least a source.
    The round silver shape to the forward right of the oil filler cap......any thoughts in regards to a possible cause? Severity? Ease of resolve?
    Cheers,
  3. Re: MK7 2.0 TDI GT (184), Oil leak from top of engine
    1830 Post(s)
    Was the cover replaced or just the gasket?
  4. Re: MK7 2.0 TDI GT (184), Oil leak from top of engine
    Mar 2010
    Wakefield
    On both occasions, just the gasket replaced.
  5. Re: MK7 2.0 TDI GT (184), Oil leak from top of engine
    1830 Post(s)
    Take the oil filler cap off with the engine running, see if you get a hiss as it comes away.
  6. Re: MK7 2.0 TDI GT (184), Oil leak from top of engine
    Mar 2010
    Wakefield
    You mean whilst running, to see if it was holding pressure?
  7. Re: MK7 2.0 TDI GT (184), Oil leak from top of engine
    1830 Post(s)
    I did one a week or so back from another garage who had given up, when I released the filler cap engine OFF, it went whooosh. New cam cover off the shelf at TPS, problem solved.
  8. Re: MK7 2.0 TDI GT (184), Oil leak from top of engine
    Mar 2010
    Wakefield
    Very Interesting, thank you.
    Did you find the actual cause, ie a crack...a blockage...a gasket tear etc? Out of interest, approx how much was the cam cover?
  9. Re: MK7 2.0 TDI GT (184), Oil leak from top of engine
    1830 Post(s)
    The moulded in vent valve inside the cover, there are two new versions depending on engine code and the most common revised number is 03L 103 469 A and these are 223.09 plus injector bolts and strictly speaking you should do the injector seats, seals and hold down plates. If the hold down plates get swapped or turned around they can snap in service.
  1. Engine oil leak
    By merce55 in forum Phaeton
    Last Post: 13-09-2016, 08:18 AM
  2. Engine leak
    By darich in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 18-03-2013, 10:08 PM
  3. Oil leak from rear of engine (2.8 ACK Engine)
    By stoocake in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-01-2011, 09:35 PM
  4. Please Help Oil leak on top of engine
    By skulz768 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-05-2009, 10:50 PM
  5. Engine oil leak
    By tel7448 in forum Passat - Archive Topics
    Last Post: 01-04-2007, 10:30 AM
